Results 1 to 5 of 5
    Full Member level 1
    Points: 2,215, Level: 10
    Jan 2005
    96
    2,215
    10
    e^jwt
    As you know, e^jwt=cos(wt)+j*sin(wt)
    I can plot its diagram by mathlab.
    And get the result of a sinusoidal.
    But, when I try another numers, 2 or 3 instead of e in above equation.
    The result is still like sinusoidal.
    How to explain it?
    j is key point, and j=sqrt(-1).
    It is really beyond my imagination.
    Points: 17,526, Level: 32
    Oct 2005
    India
    1,804
    17,526
    32
    e jwt
    if you visualise the numbers u substitute say 2 or 3 as e^k you will realise that you are just multiplying e^jwt by a constant and hence you are just multiplying a sine wave with a constant and hence will obtain a sinusoid only....
    Full Member level 1
    Points: 1,716, Level: 9
    Jul 2007
    101
    1,716
    9
    mysterious equation
    Well, this question, you are anxious about, is not so strange as it probably seems to you. The explanation of this circumstance is the followin:
    1) Remember the main logarithmic identity, studied in the school course of algebra:
    e^(ln(a)) == a, if a>0. Now let's apply this expression to your example:
    2^(jwt) = e^(ln(2^(jwt))) = e^(iwt*ln(2)) = exp(jwt*ln(2)).
    2) Now we simply adjust the Euler formula, which you mentioned, to exp(jwt*ln(2)) and get the following:
    exp(jwt*ln(2)) = cos (wt*ln(2)) + j * sin(jwt*ln(2)).
    So as you see again we obtained harmonic functions, which represent real and imaginary parts correspondingly. The 90 degrees phase shift preserves, the only difference - is that these functions are scaled (compressed, respectively the x-axis).
    It's obvious, that any substitution of e doesn't change the sense.
    With respect,
    Dmitrij
    Full Member level 1
    Jan 2005
    96
    2,215
    10
    e(jwt)
    When I type 2^(sqrt(-1)) in mathlab, I can get sinusoid figure.
    But, how is it souce code?
    Oct 2005
    India
    1,804
    17,526
    32
    e^-jwt
    well it is just based on the individual function i.e.sqrt and the exponentiation(^)
    the code of can be seen by using help.....
