lty
Junior Member level 3
Hi, all:
I am doing scan chain synthesis for atpg, I made assignment for scan count=44, scan port for every scan chain. but after ic_shell finish this scan synthesis, I found it only output 14 scan chain. I got a warning message:
WARNING: Inconsistent 'pre_show scan chain count' (20) and 'final scan chain
count' (11). Please check (a) scan chain stitching results (b)
set_scan_port commands. (DFT_Warn_071)
Then I removed scan ports assignment and remained scan chain count=44. then it output 44 scan chains, only the ports of these chains is not connnectted.
pls give some suggestion of why I met this problem and how I could improve it.
very thanks!
I used TESTCRAFT to do my scan synthesis. thank you!
very thanks!
