Please correct C source code for frequency meter(pic16f628a)
ajit123456
Newbie level 3
Hi, I recently downloaded source code in C for frequency meter using pic16f628a.
But when compiling it in MPLAb v8.60 & HITECH C compiler, it shows no. of errors & warnings. Please anyone correct the C code. I'm new in pic project.
  • Frequency-Counter.zip
The reason for the numerous errors is due part by the fact the C file was written for the HITECH PIC compiler, however the delay.c file was not included. So you'll have to write your own delay routines.The MPLAB requires a different header file, something like:
#include <p16f628a.h>
Hence the code at the beginning of the file:
#include <pic.h>
#include <delay.c>
__CONFIG(WDTDIS&PWRTEN&LVPDIS&XT);
By the way including another 'c' file is bad form, you should always write a header file with the function prototypes and include that instead. MPLAB also uses a different CONFIG macro.
If you desire to compile the code in MPLAB or HITECH you'll need to make some changes. I'll download the zip file and make the correction for MPLAB later tonight or tomorrow, as soon as I have the time.
Ciao
Thanks guys for your response.
Here is the screenshot of errors.
  • errors.rar
Hi, do you have the correct code for the frequency meter for the pic16f628a? could you send it to me?
