Is it possible to serially control stepper Motors with PIC/AVR micro-controllers with
jatindecoded
With simple input, the direction, the speed and the number of steps etc can be setup by user and stepper motor will run that way. As off now , I program PIC with MPLAB +CCS C Compiler . Thank you.
Yes but you need a stepper motor driver/controller. Refer the following link for such controller
https://electronics123.net/amazon/datasheet/KT-5190%20HS20%20Manual%204%20axis.pdf
yes thats what i'm trying to make from scratch. I want to make a 3 axis stepper motor controller for a bipolar motor . What I have decided is to make stepper driver for motor separately controlling from a single PIC. It would be great if you could help me with code or give some good direction as I'm only a novice as far as PIC is concerned
Will depends in motor power and type (4, 6 wires), but u can also drive a step-by-step motor with 4 MOSFETs, driven by a uC with the right 4bit sequence for activate the stepper coils.
Straightforward example : **broken link removed**
In which mode the controller works as a variable gain amplifier?
On-off
PID
integral
proportional
