Voltage spikes on the Gate-source of upper H-Bridge MOSFETs (for LLC converter)
Neelsama
Newbie level 3
Here is a problem I encountered in the Lab today and would love to hear your thoughts about it.
I was testing a LLC converter I designed under high voltage (500V) and after couple of test under low power (100kHz, 300ns dead time), upper MOSFETs (SCT3160) of H-bridge got damaged. Both of the damaged MOSFETs had gate and source shorted. I replaced the both MOSFETs with new ones and checked the drain source voltage with a differential probe and saw there were a voltage spike of 30V on each of the upper side MOSFETs. However, there was no visible spikes on the MOSFET gate of lower bridge. This voltage spike is not present when the no voltage is applied to the input terminals of the H-bridge and increases with applied voltage. Since, I am not drawing any current it is surely not due to hard switching of the MOSFETs. Which begs the question what can cause this spikes?
Here are some information on the design:
My gate driver schematic for one leg looks like this:
The upper bridge is supplied from a separate 15V isolated DC-DC converter (SPU02N-15). The schematics for this is shown in attachment.
I don't know if it helps here is a snapshot of the layout of the MOSFET gate drivers
Since this is the first time I have undertaken hardware project my knowledge in this field is limited and your kind help is solicited.
#1 cause of spikes is stray inductance against a hard
switched current.
Whether this is in the driver-gate-source-SW loop or
the VB-gate-SW loop, is one thing to figure out - is
the spike driven out the HO because it must follow VB
or is it that HO, gate are fine w.r.t. SW at the driver,
but the gate in-the-moment is jacked by inductive
overshoot on the upper FET source leg inductance?
Adding 'scope probes can corrupt the measurement
in high dV/dt activity, adding to the "pull" against the
common mode dV/dt and injecting currents where
there were none (or less). This could itself be a
diagnostic (if you blew up FETs more, or less, when
poking a particular flying node).
Speaking of flying nodes, I don't think 2.2uF is very
good for driving a (say) 2nF Cgg FET, and especially
not if this fly-cap has poor ESL / ESR. I would at least
give it the same HF 100nF cap as you see on the
input supplies. Maybe even more as it's a harsh dV/dt,
dI/dt environment.
the spikes are likely a result of your probing - can you post a pic please? if you have too much dead time you may be hard switching the top fets - and yes a 470nF MLCC across the 2u2 is a good idea ...
Wait, you see a 30V spike on the Vds of the upper FETs, or their Vgs?
Your layout definitely has excess inductance in the gate drive loops. But I don't think that alone can explain 30V showing up on the gate...
I'm betting the 30V spike you're seeing is due to bad probing, and the failure lies elsewhere, like cross conduction or excessive switching losses.
light load ( at usually high frequency ) is one of the danger spots for LLC if the dead time is not perfect ...
a good check on your diff probe is to put both probes on the source of the upper device ( i.e. shorted together on the source ) - a really good diff probe will show a flat line - a cheapy one will show the 30V spike you mentioned earlier ....
Reactions: FvM
    FvM
switched current.
dI/dt environment.
Thank you very much for your reply. Its interesting to hear your point of view.
Here is a pic How my Mosfet H Bridge looks like ( they are mounted on a heat sink) and
here is how I connected to take the measurement of V_GS of Upper and lower MOSFET of the H-Bridge.
Bellow are also two snaps of the osci Gate to source voltage measurement of lower and upper bridge.
I managed to damage one more upper MOSFET during taking measurement today. I am beginning to think the way I am probing is the root of the problem. How do you suggest should I probe to find out if switching is taking place or not without ideally not damaging the MOSFETs? Is it safe to use the above probe setup when no High voltage is applied to the bridge? Would be awesome if you can suggest some reading material on this
Regarding your other suggestion I wil try to replace the 2,2uF between VB and VS with a 100nF MLCC.
One more thing I would like to bring to your attention is the boot strap arrangement for the upper MOSFETs. I avoided the boot-strap diode by connecting VB to + of 15V isolated DC-DC and -ve end to switching node. I have used no bootstrap diode in between them. Do you think this could cause potential problem? Additionally I used a 10k resistance between gate node and switch node to make sure gate voltage is not floating? Is that a good practice?
I have attached some additional photos for your kind perusal. Looking forward to your inputs
We are curious to see the result of the common mode test suggested by Easy peasy.
I don't see problems with the gate drive. You need either an isolated supply or bootstrap. If you have one you don't need the other. The 10k might be a risk if bootstrapped (it drains the bootstrap cap) but not with a proper supply on the gate drive.
The "flying supply" could be a bad actor if it has any common
mode sensitivity (dV/dt, w.r.t. Earth, might push on the
set voltage, could be overshoots, etc.). There are gate drive
DC-DC parts and modules meant for high dV/dt applications,
so presumably there are others that make these products a
better idea....
Just one of the things already suggested to probe, and see.
With that clip-lead arrangement you have a large "pickup
loop" inherent to the probe, and will see ambient magnetic
field stepping on the electrical waveform.
You might at least co-bundle the red/black clips minimizing
the loop area, with one eye on the 'scope to see how any
artifacts may change (or hopefullly go away, although this
has not to do with the actual burning of FETs most likely -
still you'd like to be homing in on the real problem, not
chasing ghosts).
Open cores are really bad about "spraying" magnetic field.
Pot cores (closed magnetic path) are nicer neighbors.
you should put a common mode choke ( size commensurate with current flowing ) right at the upper gate drive on the isolated DC as it comes in - this will stop all the connected stuff flapping up and down at high volts at switching frequency .... one on each high side device
Thanks for your feedback. I am waiting to receive the new FETs from the supplier and try your suggestions out. In germany everything takes time :)
I will keep you posted about further developments.
I will give it a try. I found this one in my lab:
https://katalog.we-online.de/pbs/datasheet/7448013501.pdf and has around 2x0.5 mH inductance? Will this suffice?
Once more question regarding adding a 470nF in parallel to 2,2uF. I really don't have a pad free to put them together. What could be alternative to your opinion? I was thinking of replacing a 100nF MLCC to 2,2uF.
Thank you in advance!
It's not about C alone, it's about whether the C in series
with its R, L internal "baggage" can jump up in time to
quench common mode excursion driven spikes. More C
helps little if its ESL, ESR are too high.
For experiments, you can stack caps on each other. But
if the real problem is a bad route (large loop, skinny trace,
lonely via) there may be no such thing as "good enough"
at the component level.
A "RF" 100nF cap will be better than another "Audio" 2.2uF
most likely. Bargain bin caps are anybody's guess.
