Help me with designing a Gaussian filter with discrete components
Rayengine
Full Member level 5
Hong Kong
Anyone has experience in design the Guassian filter by discrete components? How to control BT likes = 0.3 or 0.5.
Any answer welcomed.
Is it necessary to implement it by filter circuit?
I knew that many transceiver chips has implemented on-chip. But if some simple transmitter with high data rate, you should take care the sideband of the transmit spectrum.
Here is a program
You can get a trial version of Super Filter that will work for a limited time at **broken link removed** It has gaussian filters as well as raised cosine types.
