Puppet123
Full Member level 6
Hello,
I am getting the following errors when I run Momentum Virtuoso from Cadence Virtuoso Layout to do EM Simulation of Cadence Virtuoso Layout using Momentum.
Does anyone know what they mean or have they ever encountered them ?
See below.
Thank you.
See below.
Thank you.
Code dot - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 WARNING (ADE-5033): Cannot find the environment variable 'writePinShapesToGeomHierLevel' for tool 'adsMom.envOpts'. Its internal default value will be used. WARNING (ADE-5034): Unable to access the default environment variables in the simulator's global .cdsenv file ('<your_install_dir>/tools/dfII/etc/tools/adsMom/.cdsenv') because the file is missing or out-of-date. Till this problem exists, internal default values will be used for these environment variables during this session. WARNING (ADE-5033): Cannot find the environment variable 'writePinShapesToGeomHierLevel' for tool 'adsMom.envOpts'. Its internal default value will be used. WARNING (ADE-5034): Unable to access the default environment variables in the simulator's global .cdsenv file ('<your_install_dir>/tools/dfII/etc/tools/adsMom/.cdsenv') because the file is missing or out-of-date. Till this problem exists, internal default values will be used for these environment variables during this session. WARNING (ADE-5033): Cannot find the environment variable 'simplifyShapeArrayPref' for tool 'adsMom.envOpts'. Its internal default value will be used. WARNING (ADE-5033): Cannot find the environment variable 'simplifyShapeArrayPref' for tool 'adsMom.envOpts'. Its internal default value will be used. WARNING (ADE-5033): Cannot find the environment variable 'simplifyLayerNameLengthLimit' for tool 'adsMom.envOpts'. Its internal default value will be used. WARNING (ADE-5033): Cannot find the environment variable 'simplifyLayerNameLengthLimit' for tool 'adsMom.envOpts'. Its internal default value will be used. WARNING (ADE-5033): Cannot find the environment variable 'simplifyShapeArrayIncrement' for tool 'adsMom.envOpts'. Its internal default value will be used. WARNING (ADE-5033): Cannot find the environment variable 'simplifyShapeArrayIncrement' for tool 'adsMom.envOpts'. Its internal default value will be used. WARNING (ADE-5033): Cannot find the environment variable 'simplifyShapeArrayStepRatio' for tool 'adsMom.envOpts'. Its internal default value will be used. WARNING (ADE-5033): Cannot find the environment variable 'simplifyShapeArrayStepRatio' for tool 'adsMom.envOpts'. Its internal default value will be used. WARNING (ADE-5033): Cannot find the environment variable 'resultsDialogColWidthList' for tool 'adsMom.envOpts'. Its internal default value will be used. WARNING (ADE-5033): Cannot find the environment variable 'resultsDialogColWidthList' for tool 'adsMom.envOpts'. Its internal default value will be used. WARNING (ADE-5033): Cannot find the environment variable 'resultsDialogMaxWidth' for tool 'adsMom.envOpts'. Its internal default value will be used. WARNING (ADE-5033): Cannot find the environment variable 'resultsDialogMaxWidth' for tool 'adsMom.envOpts'. Its internal default value will be used. *WARNING* envGetVal: Could not find variable 'simplifyShapeArrayPref' in tool[.partition] 'adsMom.envOpts'. *WARNING* envGetVal: Could not find variable 'simplifyShapeArrayPref' in tool[.partition] 'adsMom.envOpts'. *WARNING* envGetVal: Could not find variable 'writePinShapesToGeomHierLevel' in tool[.partition] 'adsMom.envOpts'.
