Do we name the circuit types according to their input?
chang830
Full Member level 5
We used "differtial circuit", "single ended circuit" to decribe our circuit. It is for input and not output, right? I mean, if my citrcuit is differential input and single ended output, the circuit contains a dif-to-single converter in it. We still define it as differtial block, right?
Thanks
Re: differtial circuit
Right ..
Rgds,
IanP
    chang830
differtial circuit
yeah
But if citrcuit is differential input and single ended output and it's load resistance not current mirror,it will not restrain the common-mode signal.
The common-mode signal here you meant input signal or output signal?
Since it's single-ended output, there is no common-mode signal for the output signal.
hbchens said:
yeah
Thanks
There are fully differential amplifiers if this is your hidden question (differential in-differential out).
In common OA terminology you have right.
But in RF, a single ended circuit could be the input (or the output) of transciever, as well a differential circuit could be another input (or output) of the same transciever.
Differential versus single ended means in RF an overal gain of 3dB.
Even a single ended output could have "common mode", but is called usually offset.
I think your answer is wright .
