Need equivalent code VHDL testbench for Verilog testbench
win2010
Member level 1
It has reading external file and applying different values. Need code in VHDL pls help out.... It work fine in modelsim 6.5.
module Buf_tb;
// Inputs
reg clk;
reg reset;
reg [15:0]K_ldpc;
reg [0:0]input1;
integer file;
// Outputs
wire [0:0]output1;
// Instantiate the Unit Under Test (UUT)
Buffer_parity_gen uut (
.clk(clk),
.reset(reset),
.K_ldpc(K_ldpc),
.input1(input1),
.output1(output1)
initial begin
clk = 1;
file = $fopen("Input.txt", "r");
forever #50 clk=~clk;
end
initial begin
reset = 1;
#40 reset = 0;
end
always@(posedge clk)
if (reset==0)
begin
$fscanf(file,"%b",input1);
end
initial begin
K_ldpc=16'd32400;
end
endmodule
As a VHDL beginner, Instead of getting someone else to do it for you, why not have a go yourself?
