eepty
Full Member level 2
How to calculate temperature resistance for Ni-RTD?
I would like to build a circuit to read the signal from a thermopile temperature sensor which has build-in RTD temperature sensor for cold-junction compensation. The datasheet of the sensor is here. I need to know the resistance value of the built-in Ni-RTD at some particular temperature to build the circuit. I search the web to check how can I calculate the resistance value but all I could find is the formula for a platinum RTD. Could you guide me how to calculate the resistance value for a Ni-RTD?
My target temperature is from 0-85C only.
Thank you very much.
