What is the significance of double dummy poly on both sides for every transistor?
cmoslayoutguide
Newbie level 3
Is it just to reduce the effect the of STI ?
Re: Double dummy poly in deep submicron technologies
Is it .... to reduce the effect the of STI ?
Yes, and additionally to allow for a consistent environment if matching is important.
These dummy polys will help to prepare the mask or these are also part of process poly?
They are processed like any other poly, i.e. they are real existent. That's the best way to provide a consistent environment in the surroundings - as well as relieving STI stress (mainly due to the additional distance).
poly is formed by Uv light. duo to diffraction at grid of UV light. another gate will form near to actual gate . to avoid that we r placing dummy poly . this will cancel the additional poly by distractive interferes
Hi velkumargn
Could you just brief about what you said ?
Regards
Kishan.B
193nm lithographic process near UV light grid light will diffracted, so UV will go and form gate at some other place. If drain or source will come that place additional device will form with DRC. to avoid that we add dummy poly . Due to distractive interference it will cancel each other
