eagle1109
Full Member level 6
- Joined
- Nov 20, 2014
- Messages
- 390
- Helped
- 4
- Reputation
- 10
- Reaction score
- 7
- Trophy points
- 1,298
- Location
- Saudi Arabia
- Activity points
- 5,927
I ran through this chapter and reached this circuit which is fine and I solved the previous controlled 1-ph circuits' examples and I understand the parameters of the different voltages, current, power factor ... etc.
But when I reached the 3-ph controlled circuit with resistive load, I found different voltages that I couldn't find a source that explain them all. But I understand the rest of the measuring parameters.
This is the circuit:
This is the solution of the example:
I want to know what are the naming & difference between VL(m), Vphase & Vm?
