[SOLVED] Altium Designer - Multiple instances of the same Layout design on the same page
kororos
Hello all,
I have designed my PCB Layout in Altium Designer 10. The size of my layout is on purpose 8cm*5cm. the reason is that I want to make four of those boards on a single 16cm*10cm board. However, I cannot figure out, how to print my layout 4 times on a matrix configuration.
Can somebody help?
Thanks
Lefteris
you can use panelization in altium. place->embedded board array.
but dont forget the adding new pcb to the projecs!!!
Thank you very much for the help.
This is what I have been looking for.
Lefteris
