kaitokid41
Newbie level 6
Hi! I'm new here and I really need your help. I need to send a frame using an RF module which will be serial transmission. I'm using PIC18F4550 and a mikroC compiler. I need to transmit the data from a device where I used the microcontroller to my computer using Visual Basic 6 or PHP (i'm planning to put a database later), vice versa. This will be the frame I need to send with at least 1 byte each:
SYNC | RECEIVER | SENDER | LENGTH | DATA | CHECKSUM
Advance thank you for the help!
EDIT: Typo Error. Sorry for that
