How to design coaxial feed for fractal microstrip antenna using CST (Need Help)
vadhil
Jakarta - Indonesia
Hey vadhil,
In order to design the coaxial feed you first need to substract a circle of 2mm from the substrate at the point where you need to place ur feed.
Then using cylinder to fit in the substratced place by giving it height in -z as your substrate is laying on 0. After this you need to design two pins
of diameter 1.6mm i.e by using cylinder placing the pins inside the above cylinder i.e starting from -z upto the substrate height and then second pin from substrate height upto the patch.
Assign vaccum to the cylinder with 2mm of diameter and assign PEC to the pins.
Reactions: vadhil
    vadhil
hi arxlan..
thanks a lot for your answer.
its very helpfull. :D
but, I still confuse about the pin.. can u show me in a picture or you can draw how pin look like..
I'm so sorry for disturbing you..
thanks before.
Attached are the pictures of coaxial feed.
Now you can easily understand about the inner pins and the outer conductor and i already told you the diameters. Just make sure before starting
you need to subtract a circle from the substrate with diameter=diameter of external cylinder.
For the excitation you need to draw a circle at the bottom of the external cylinder and then assign waveport to it, like this:
Now just try to make it according to this procedure and hopefully you will get your results.
If you got any problem, you can ask me.
Regards,
Arslan.
Reactions: vadhil
    vadhil
I have seen your design, probe feed is not correctly defined. I will try to check it back again and will provide you by
correcting it.
Regards,
Arslan
Reactions: vadhil
    vadhil
