[SOLVED] Question about programming trick
if it takes a few seconds then the input is probably read a few thousand time before the wrong data happens so I wonder why at that particular moment, do you have anything else in your code that could interfere in the reading process, any interrupt or some other peripheral?
Hi guys, :)
I Have question :) in this scenario I have 8 parallel inputs w/ 8 switches and it is being pulled up by 8 resistors, so the normal values of my input read by the PIC when no switches pressed is 255.(all 8bit input are high/1)
the switch used is a push button switch.. NORmally open
when I press one switch located at PORTA.RA0 the input value will now be 255 -1 = 254..
the switch is momentary when I dont push it it will go back and the input value again will be 255.
so now the problem is I want to hold that value until the next activity of the switch. (the value 254)
I want to store that value inside a variable without losing it even if the switch is not press anymore
I tried something like this but after sometime inside a while 1 loop the value 254 disappear..
this is my code:
PHP:
if(input != 255) //when any of the switch is pressed
store = input
return store;
The above bold letters indicate that you are using 8 pins for switches...so I thought to use Intr on Change.
Now, I am confused...what is it exactly you are doing :) :) ;-)
Can you share schematic of hardware design?
I already disable all peripheral I am using..
I just only input shift registers..
okay.. I will update this thread with complete information.
I will upload here the simulation and the source code I am workin on..
---------- Post added at 10:25 ---------- Previous post was at 10:23 ----------
the schematic posted by alexan_e is what exactly I am using..
whatever input received from that shift register will be copied to another port.. that is only I want to do..
I will upload here my work..
you can try to validate the data before using them by comparing that the last x number of results are the same, you read the input very fast anyway so event a momentary button press will give a few hundred times the same result.
As an additional advantage you can probably use it to debounce your buttons in the real circuit
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
int get_inputDATA()
    int data = 0,i;
    static int prev_data, count;
    SPI_InLatch = 1; //load data
    delayus(1);
    SPI_InLatch = 0;
    SPI_PLOAD = 0;
    delayus(1);
    SPI_PLOAD = 1;
    for (i=7; i>=0; i--)
        if(SPI_SI)
        data |= (1 << i); //store data received
        toogle_clock();
    //return data;
    if (data==prev_data) count++;  // increment while getting the same data
    else {prev_data=data; count=0;} // if not same as previous data keep new data and reset counter
    if (count==10)  // if data was the same for 10 times or you can try more times
        count=0;
        if(data != 255)
        store = data;
    return store;
Alex
Hi Alexan_e..
Still the same value is not retaining.. Im attaching the proteus simulation and the source code..
  • button.7z
in proteus simulation I get a watchdog expired warning every 2.3sec , this is probably the reason that the value is lost, a total reset
what do you mean? in my simulation?
---------- Post added at 12:22 ---------- Previous post was at 12:21 ----------
okay.. I see it now.. I will try to hardcode the configuration bits and disable the watchdog timer.
yes, check the simulation log while running the simulation
I see it now.. it's weird I can't disable the WDT... it's weird . WDT is not running in simulation in some PIC simulation..
I have no idea, maybe it is a bug of proteus model, if the watchdog is not working in reality then the result will be correct
---------- Post added at 13:41 ---------- Previous post was at 13:40 ----------
if the watchdog is not running in your ide simulator then it is probably a proteus model bug
yes.... WE wasted time because of this.. now I lear again from you.. next time I will always visit the protues log... Thanks so much
I spent almost 24hours for this problem...
hi,, the problem was already spotted.. the watchdog timer keeps reseting the MCU.. it's weird ..
---------- Post added at 14:05 ---------- Previous post was at 13:45 ----------
Problem solved!!!
for future reference to other members. if you are working with PIC18f452 in proteus YOU NEED TO DISABLE THE WATCHDOG TIMER...
special thanks to Alexan_e..
thanks so much..
