[SOLVED] sensing a signal async to clk
emresel
Full Member level 5
Turkiye
Dear friends;
Is it possible to catch a signal like attached, it is async to clk and duration might be shorter than a half period of clk.
It should be catched until next rising edge of clk and reset output again.
Do you have any synthesizable vhdl proposal circuit?
if sygnal = '1' then
out <= '1';
elsif Clk'event and Clk = '1' then
out <= '0';
end if;
Reactions: emresel
    emresel
Thanks friends;
That helped me. But i have a few questions more. Since i am trying to learn vhdl/fpga concept myself sometimes need more expertised help. Hope you appreciate.
The code above is woking but when i change it like below, it is not synthesizable any more.
process (input, clk)
begin
if clk'event and clk = '1' then
output2 <= '0';
elsif input = '1' then
output2 <= '1';
end if;
end process;
It says "statement is not synthesizable since it does not hold its value under NOT(clock-edge) condition". Actually i can't figure out what is going wrong.
Could please explain some more on it?
Thank you
PS:I am doing this kinds of things sometimes and then stuck.
The construct is not following the required syntax for aysnchronous + synchronous register action which have been previously suggested in this thread by treger. The order of statements matters.
Thanks,
While i am checking the net also found the note in a tutor;
The condition for synchronous actions has to be the last condition of the if structure because asynchronous control signals are usually treated with higher priority by the underlying hardware cells
I think it may be noted as a general rule...
Yes, you can read more about it in text books dedicated to VHDL for hardware synthesis. You can also refer to IEEE Std 1076.3, which tries to define a portable subset of synthesizable VHDL.
Thank you FvM;
While searching 1076.3, I found also 1076.6 which seems a useful doc.
That tells "A clock edge shall only appear in the last elsif condition." point, too.
Although 1076.3 is also related to synthesis, I actually meant 1076.6. Please apologize for the confusion.
