abhilash64
Newbie level 5
i am new to this forum and this is my first post.
i want to build this project. here is what is want to achieve:
1) there will be a sensor, when it is activated it will send a signal to the microcontroller and then the microcontroller will start a timer for 10 seconds.
2) a fingerprint scanner will also be present and if it does not detect a valid finger print within these 10 seconds, a signal will be sent to the microcontroller, which in turn will send an sms using a gsm module indicating unauthorized access. and then the microcontroller will turn off a relay( the relay can be connected to anything...say to turn off a bulb)
3) the relay can then be again turned ON only by a valid finger print scan or a sms by the owner.
i need a detailed help for this project.
i hope i will get all the help that i would need.
