Cheap LCR meter to measure leakage inductance in transformer?
grizedale
Advanced Member level 3
Is it ok to use a cheap standard LCR meter to measure leakage inductance of a switch mode transformer?
The transformer is for use in a 250W half bridge converter with vin = 90vac to 265vac.
-there is no PFC stage as its not required for our audio application.
The outputs are +-50V, -each at 130W, and 16V at 6W.
Depends on what kind of leakages you're talking about. For measuring several uH or more a DMM with an LCR function might be good. But anything less than a couple uH will require a good benchtop LCR meter with kelvin sense leads, and a high measurement frequency. I own an old stanford research SR715 LCR meter which is pretty good (measures up to 10KHz), but a LCR720 (100KHz) would be much better. They show up on ebay occasionally for 150-400USD.
The converter will run at 11KHz, is it important to measure leakage using this frequency?
No, leakage inductance shouldn't change with frequency, unless you go way up in frequency near the resonance of the transformer.
