Naman100
Newbie level 2
Hi everyone,
I am trying to run 16x2 lcd with lpc 2148 on proteus.I was successful in running the lcd when i used 8 bit mode but when im using 4 bit mode,nothing is getting displayed on the lcd except moving cursor..Please help.Thanx in advance..
Im posting my code below..
Code C++ - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 #include <LPC214x.h> void cmd(unsigned char d); void datal(unsigned char t); void delay (int count); int main() { int i; unsigned char name[]={"Naman"}; IO0DIR=0x0003F400; //0b0000 0000 0000 0011 1111 0100 0000 0000 delay(100); cmd(0x28); cmd(0x01); cmd(0x02); cmd(0x06); cmd(0x0e); for (i=0;i<5;i++) { datal(name[i]); } while(1); } void cmd(unsigned char d) { int a=0; a=(d>>4) & 0x0F; a=a<<14; IO0CLR = 0x00003000; IO0SET = 0x00000400; IO0CLR = 0x0003C000; IO0SET = a; delay(1000); IO0CLR = 0x00000400; a=d & 0x0F; a=a<<14; IO0CLR = 0x00003000; IO0SET = 0x00000400; IO0CLR = 0x0003C000; IO0SET = a; delay(1000); IO0CLR = 0x00000400; } void datal(unsigned char t) { int b=0; b= (t>>4)&0x0F; b=b<<14; IO0SET = 0x00002400; IO0CLR = 0x0003C000; IO0SET = b; delay(1000); IO0CLR = 0x00000400; b=t&0x0F; b=b<<14; IO0SET = 0x00002400; IO0CLR = 0x0003C000; IO0SET = b; delay(1000); IO0CLR = 0x00000400; } void delay(int count) { int j=0, i=0; for (j=0;j<count;j++) for (i=0;i<35;i++); }
