IGBT module having 6-IGBTs
garg29
Advanced Member level 1
hello,
I have just started working on 3-Phase AC Motor Drive (VFD) for 1st time in life. My motor is small requiring less than 4 amperes (starting current must be high). I have selected dsPIC30F2010 as controller & Six FGA25N120ANTD IGBTs for drive. Instead I was thinking to use a IGBT module having 6-IGBTs inbuilt but I could not find one in market. Can you please suggest a one which is easily availabe in market 25Amperes would be more than suffiecient. Please see the basic block diagram below(taken up from microchip). I just want to make sure whether the way & my selected components are right or not.
I have to (& will) design the AC Drive anyhow. Best of luck to me ;-)
with best Regards & thanks in advance,
Garg
6 in a sigle package is i think is not available......you can try 3 of these maybe...
Hi
You can find FSBF15CH60BTL produced by FAIRCHILD in market but that module work in 16A and 30A in the maximum current rate.
hey garg : just let me take my word back...this one is a cool product....
Check this:
w5jgv.com/hv-ps1/pdf/fuji_igbt_application_manual(REH984).pdf
It is the application manual of Fuji's IGBT modules.
I'm not sure, but I don't think you can get IGBT modules at such a low current rating.
Hope this helps.
Tahmid.
Thanks guys for replying.
So, what do you suggest finally, should I go separately for Six IGBTs.
ea.arun you are from chennai, I'm too from India. can you please suggest some component supplier for your suggested IXYS :FII 40-06D
Secondly Tahmid, how much minimum rating 6-IGBT module is available.
Thanks.
