Leslei
Newbie level 3
I am extremely new to this area and need help with obtaining the axf files with cortex m0 target, Please guide me where to begin and which tutorial to go through. I have reached dead ends in everything I have tried. Thank you
ELF files are used when we use JTAG for loading the executable into the ARM. the file format is ELF.
in keil 4 and in keil3 in the options for target if you select debug and utilities in the settings in project and set as a device instead of simulator and compile the program and see the output generated it will be in ELF format, which is understood by JTAG debuggers.. JTAG and ICD do not understand pure format of HEX. so it is in ELF( Extended Link Format)
did you try help in keil 4... it has everything which you usually dont get in internet.... and what you get in intrnet is a copied document of the help topics.....
I did debug and then only changed
there was no warning.shud i include the file "STARTUP"
The first error i got (when started ARM C programing) also was missing .axfI am extremely new to this area and need help with obtaining the axf files with cortex m0 target, Please guide me where to begin and which tutorial to go through. I have reached dead ends in everything I have tried. Thank you
