dmahale007
Newbie level 6
I am designing a microstrip antenna with microstrip line feed technique, I need the equations for the width and length of the microstrip line feed plz help me
The input impedance of patch is 233 ohms so the impedance of strip line should also be 233 ohms k, but the co-axial cable has impedance of 50 ohms so how to match them without using incept feed
in this case, i suggest to use balun or impedance transformer or taper feed-line
