[SOLVED] How to interface piezo buzzer using uln2003 ?
psrkiran
Newbie level 6
In my circuit i have a ULN2003 which has 4 unused inputs so i want to use one pin for interfacing piezo buzzer is it possible ? if so how to do it ?
Connect buzzer (+) terminal to +5V and buzzer (-) terminal to an output of ULN2003 .
why not possible just connect + to 5 v and - ve to output of uln 2003 cheers
Thanks everyone for replying
Its not working for me but when i interface it with two 1k resistors and one general purpose transistor its working but i can't understand why it is not working with
ULN2003 please help me.
Are talking about a piezo buzzer with built-in oscillator, that has to be driven by a dc voltage or a plain piezo transducer that needs AC drive?
All the conventional buzzer's are built in oscillator, ur only required to power it up using its appropriate voltage(5V/12V)
When is interface buzzer in this way
The Buzzer is working properly
But when i interface it in this way
It is not working Why ?
The first three input pins of ULN2003 are connected to three relays ans they are working properly without any problem
Does you mcu have open collector output?
If so use a pull up resistor in the input of the ULN2003
Alex
I don't know anything about open collector output but the mcu i am using is At89C52 which needs pull up register across port 0
Open collector means that the output transistor can only sink current (provide ground) or leave the output floating.
Think of the open drain/collector as a switch to ground, it either provides ground (on) so you get a low output
or leaves the output floating (off) and you get a high output but only if you have a pull up resistor.
Alex
P.S i have added a picture in my previous post
