Light sensor w/ photoresistor & 741 Op-Amp
wt200999
Newbie level 1
I came up with a circuit for sensing light using a photoresistor and a 741 Op-amp. Here is my circuit diagram. (sorry for the crude drawing)
With a power supply at +5v The output I get from the op-am I was expecting to be either 5v or 0v, but instead I get ~4.5v and ~2v for either light or dark. I eventually wanted to interface 3 of these to inputs on 7400 series logic.
If you don't have a "rail-to-rail" op amp, the output won't swing all the way to 5V and 0V, you'll wind up a few diode-drops from it (due to the transistors internal to the op-amp that swing the output voltage around). You could run your signal into a comparator or schmitt-trigger to clean it up to a nice 5/0V range.
See also: Google
Schmitt trigger - Wikipedia, the free encyclopedia
