karthickb3e
HI i need 230/110 rectifier with filter circuits with details ...... please help me
There is no such rectifier which works on specific voltages. If you are asking for a rectifier which converts 220 to 110, you may use a single diode in series which will cut off the half cycle of the AC form which will result in 110VHI i need 230/110 rectifier with filter circuits with details ...... please help me
Cheers
But still you didnt clarify what you need. I didnt get what you expect with your OP which is quite confusing.sir i need brige circuit with values of diode and capacitor ........thank u very much
Cheers
Use 220/110V transformer of current rating according to your application
use diodes and capacitors ratings as per ur application
this is the basic circuit.
