ankitnayan
can someone pls post the code for interfacing optical mouse with pic18f4550???
i am in trouble with that..
you need to read the datasheet for the PIC. There is a huge section for clock and oscillation configuration as well as other special feature configuration before you can use them. So, try to learn them first.
