how can i interface temperature sensor to 8051
vattipalli
Junior Member level 1
how can i interface a temperature sensor to 8051 and read data from that. plz any one help me in coding part..plz...
refer 8051 by mazidi . it has everything u required regarding interfacing temperature sensors
few days back i started learning 8051 plz suggest some tips....
use ADC0804 with LM35.. check this **broken link removed** for code and schematics.
As far as i know the best way is an ADC converting output of lm35. LM35 IC has an output of 10mV/degree C and has a range of -55 to 150 degree Celsius. This is the easiest afaik
