keisini5577
Newbie level 6
hi ,
here I have a question about how to simulate a TIA. I'm working on a TIA with spectre. I want to measure its gain. How shall I establish the test bench?
I have two differential Isin with proper bias current and run the AC simulation. Then I use the direct plot "gain & phase", first click on the output voltage and then on the input voltage. Is what I get only the voltage gain of the amplifier?
How can I get the transimpedance gain?
Thank you in advance!
