jayce3390
Full Member level 6
I think it's a power supply problem.The amplifier is not supplied sufficiently and therefore supply voltage is dropping and ringing because of protection circuit..
It's my guess..
You might also want to see if the disruption is due to some nearby circuit. Often strange signals originate from "elsewhere". Move into a screen room ..... or just move elsewhere.
Are you saturating the amplifier? What if you increase the input amplitude? What if you decrease it?
Is your input really pure? Are you sure?
The ringing frequency is around 2 MHz.The picture is not clear enough to check the ringing frequency. How about adding an attenuator before the input?
What equipment are you using to produce this readout? Is it a high sample rate digital scope?
Could the 2MHz signal be an alias term in the scope?
Maybe you should look on a spectrum analyser to see if the amp is producing a very high frequency term signal that is producing an alias that looks like 2MHz on the scope.
Otherwise, if it is 2MHz then it looks suspiciously large to me.
Is it a commercial amplifier or one that is being developed?
It may be that the bias network is not decoupled adequately and this allows a form of relaxation oscillation although this usually happens at much lower frequencies. You could try placing a 1uF capacitor on the cold part of the amplifier bias line.
There does look to be some very high frequency ringing and this is a clue that the amp is going unstable somewhere.
What happens if you gradually reduce the drive level? eg reduce the pulse amplitude going in.
Is there a point where is suddenly cleans up and the ringing stops?
Also, why is the 50MHz input pulse train showing an inconsistent pulse width?
How are you generating the pulse? Are you deliberately changing the pulse width as per the yellow waveform?
Can the pulse driver actually drive a 50 Ohm attenuator/amplifier? Could it be generating the ringing problem as some form of interaction with the amplifier?
Having an amplifier with 5 - 500 MHz bandwidth doesn't necessarily mean, that it's able to reproduce pulse waveforms. Apparently, the amplifier is near to it's stability margin at high frequencies. If it's actually terminated correctly, I suspect a bad designed amplifier. In any case, a frequency domain gain characteristic would be interesting.
You say, the yellow trace shows the signal before the PA. Does this mean, the original input signal has already a varying pulse width? If so, the low frequency part of the ouput waveform won't be surprizing.
