who can share a sample Design Complier synthesis script?
wufei
Junior Member level 2
Moon
how to enable multi core design compiler
not matter what design~
I just want to study synthesis
thank you:D
synthesis script example
please look at
set timing_enable_multiple_clocks_per_reg true
Hi
here they are!:
h**p://www.cesca.centers.vt.edu/tutorial/tutorialSynopsys_VerilogSynth.php
h**p://www.cse.psu.edu/~cg577/ASSIGNMENTS/lab2/index.html
look for .scr files in the pages
* -> t
tnx
compile_ultra multiple times
Here is what I'm using:
common-setup.tcl:
Name of top-level design
set DESIGN_NAME "mips32"
# Set Design Path
set DESIGN_PATH [file normalize ~/cad/mips32]
# Aboslute path prefix variable for library/design data. Use this variable to
# prefix the common absolute path to the common variables defined
# below. Absolute paths are mandatory are mandary for heirarchical RM flow.
set DESIGN_REF_DATA_PATH "${DESIGN_PATH}/ref"
# List of hierarchical block design names "DesignA DesignB" ...
set HIERARCHICAL_DESIGNS ""
# List of hierarchical block cell instance names "u_DesignA u_DesignB" ...
set HIERARCHICAL_CELLS ""
# Additional search path to be added to the default search path
set ADDITIONAL_SEARCH_PATH "${DESIGN_PATH} \
${DESIGN_REF_DATA_PATH}/icons \
${DESIGN_REF_DATA_PATH}/itf \
${DESIGN_REF_DATA_PATH}/models \
${DESIGN_REF_DATA_PATH}/plib \
${DESIGN_REF_DATA_PATH}/tech \
${DESIGN_REF_DATA_PATH}/tluplus"
# Target libraries
set TARGET_LIBRARY_FILES "saed90nm_typ.db"
# Symbol library
set SYMBOL_LIBRARY_FILES "saed90nm.sdb"
# Extra link logical libraries not included in TARGET_LIBRARY_FILES
set ADDITIONAL_LINK_LIB_FILES ""
# List of max/min library pairs
set MIN_LIBRARY_FILES "saed90nm_max.db saed90nm_min.db"
# Milkyway refere libraries (include IC compiler ILMs here)
set MW_REFERENCE_LIB_DIRS "${DESIGN_REF_DATA_PATH}/saed90nm_fr"
# Reference control file to define the MW reference libraries
set MW_REFERENCE_CONTROL_FILE ""
# Milkyway technology file
set TECH_FILE "${DESIGN_REF_DATA_PATH}/tech/saed90nm.tf"
# Mapping file for TLUplus
set MAP_FILE "saed90nm.map"
# Max/Min TLUplus file
set TLUPLUS_MAX_FILE "saed90nm_1p9m_1t_Cmax.tluplus"
set TLUPLUS_MIN_FILE "saed90nm_1p9m_1t_Cmin.tluplus"
# Names for power/ground nets
set MW_POWER_NET "VDD"
set MW_POWER_PORT "VDD"
set MW_GROUND_NET "VSS"
set MW_GROUND_PORT "VSS"
# Min/Max routing layer
set MIN_ROUTING_LAYER ""
set MAX_ROUTING_LAYER ""
# Tcl file with library modificatiosn for don't use
set LIBRARY_DONT_USE_FILE ""
# Multi-Voltage Common Variables
# Define the following MV common variables for the RM scripts for multi-voltage
# flows. Use as few or as many of the following definitions as needed by your
# design.
set PD1 "" ;# Name of power domain/voltage area 1
set PD1_CELLS "" ;# Instances to include in power domain/voltage area 1
set VA1_COORDINATES {} ;# Coordinates for voltage area 1
set MW_POWER_NET1 "VDD1" ;# Power net for voltage area 1
set MW_POWER_PORT1 "VDD" ;# Power port for voltage area 1
set PD2 "" ;# Name of power domain/voltage area 2
set PD2_CELLS "" ;# Instances to include in power domain/voltage area 2
set VA2_COORDINATES {} ;# Coordinates for voltage area 2
set MW_POWER_NET2 "VDD2" ;# Power net for voltage area 2
set MW_POWER_PORT2 "VDD" ;# Power port for voltage area 2
dc-setup.tcl
# Source the file that is common to ALL Synopsys tools to setup commmon variables
source common-setup.tcl
# Setup variables: Portions of the dc_setup.tcl may be used by other tools, so
# do check for DC only commands
if {$synopsys_program_name == "dc_shell"} {
# Change alib_library_analysis_path to point to a centeral cache of analyzed
# libraries to save some runtime and disk space. The following setting only
# reflects the default value and shoudl be changed to a central location for
# best results.
set alib_library_analysis_path .
# Add any other DC variables here
# List of source files to read if reading from RTL
set RTL_SOURCE_FILES "${DESIGN_PATH}/src/mips32.v";
# The following directories are created and used by DC scripts to direct the
# location of the output files
set REPORTS_DIR "syn-reports"
set RESULTS_DIR "syn-results"
set LOG "syn-log"
file mkdir ${REPORTS_DIR}
file mkdir ${RESULTS_DIR}
file mkdir ${LOG}
# Library Setup: Define all the library variables shared by all the front-end
# tools. It is designed to work with the settings in common-setup.tcl without
# any additional modification.
set search_path ". ${DESIGN_PATH}/synopsys/syn \
${DESIGN_PATH}/synopsys/syn/dc \
${ADDITIONAL_SEARCH_PATH} $search_path"
# Milkyway variable settings: make sure to define the variables mw_logic1_net,
# mw_logic0_net and mw_design_library as they are need by write_milkway command.
set mw_logic1_net ${MW_POWER_NET}
set mw_logic0_net ${MW_GROUND_NET}
set mw_reference_library ${MW_REFERENCE_LIB_DIRS}
set mw_design_library ${DESIGN_NAME}_lib
set mw_site_name_mapping [list CORE unit Core unit core unit]
# The remainder of the seutp should only be performed in Design Compiler
# Include all libraries for multi-Vth leakage power optimization
set target_library ${TARGET_LIBRARY_FILES}
set symbol_library ${SYMBOL_LIBRARY_FILES}
set synthetic_library dw_foundation.sldb
set link_library "* $target_library $ADDITIONAL_LINK_LIB_FILES $synthetic_library"
# Set min libraries if they exist
foreach {max_library min_library} $MIN_LIBRARY_FILES {
set_min_library $max_library -min_version $min_library
# If in topological mode, create/open milkway library and setup TLU+ files for
# RC extraction
if {[shell_is_in_topographical_mode]} {
# Only create new Milkyway design library if it doesn't already exist
if {![file isdirectory $mw_design_library]} {
create_mw_lib -technology $TECH_FILE \
-mw_reference_library $mw_reference_library $mw_design_library \
-hier_separator {/}
} else {
# If Milkyway design library already exists, ensure that is consistent with
# specified Milkyway reference libraries
set_mw_lib_reference $mw_design_library -mw_reference_library $mw_reference_library
open_mw_lib $mw_design_library
check_library
set_tlu_plus_file -max_tluplus $TLUPLUS_MAX_FILE \
-min_tluplus $TLUPLUS_MIN_FILE \
-tech2itf_map $MAP_FILE
check_tlu_plus_files
# Library modifications: Apply library modifications here after the
# libraries are loaded.
if {[file exists [which ${LIBRARY_DONT_USE_FILE}]]} {
source -echo ${LIBRARY_DONT_USE_FILE}
dc.tcl:
# Timestamp
sh date
# Apply the dc-setup.tcl to setup libraries, paths, variables, etc
source ./dc/dc-setup.tcl
# Synopsys auto setup mode
set synopsys_auto_setup true
# Note: The Synopsys Auto Setup mode is less conservative than the Formality
# default mode, and is more likely to result in a successful verification
# out-of-the-box.
# Using the Setting this variable will change the default values of the variables
# listed here below. You may change any of these variables back to their default
# settings to be more conservative. Uncomment the appropriate lines below to
# revert back to their default settings:
# set hdlin_ignore_parallel_case true
# set hdlin_ignore_full_case true
# set verification_verify_directly_undriven_output true
# set hdlin_ignore_embedded_configuration false
# set svf_ignore_unqualified_fsm_information true
# Other variables with changed default values are described in the next few sections.
# The Synopsys Auto Setup mode sets undriven signals in the reference design to "0" similar to DC.
# Undriven signals in the implementation design are set to "X".
# Uncomment the next line to revert back to the more conservative default setting:
set verification_set_undriven_signals BINARY:X
# The Synopsys Auto Setup mode will produce warning messages, not error messages,
# when Formality encounters potential differences between simulation and synthesis.
set hdlin_error_on_mismatch_message true
# The Synopsys Auto Setup mode, along with the SVF file, will appropriately
# set the clock-gating variable. Otherwise, the user will need to notify
# Formality of clock-gating by uncommenting the next line:
# set verification_clock_gate_hold_mode any
# Set this variable ONLY if your design contains instantiated DW or function-inferred DW
# set hdlin_dwroot "" ;# Enter the pathname to the top-level of the DC tree
# If the design has missing blocks or missing components in both the
# reference and implementation designs, uncomment the following variable
# so that Formality can complete linking each design:
# set hdlin_unresolved_modules black_box
# Set SVF file to read
set_svf ${RESULTS_DIR}/${DESIGN_NAME}.mapped.svf
# Read in libraries
foreach tech_lib "${TARGET_LIBRARY_FILES} ${ADDITIONAL_LINK_LIB_FILES}" {
read_db -technology_library $tech_lib
# Read in the reference (original) design as verilog/vhdl source
read_verilog -r ${RTL_SOURCE_FILES} -work_library WORK
# Set reference design
set_top r:/WORK/${DESIGN_NAME}
# Read in the mapped design
# For verilog
# read_verilog -i ${RESULTS_DIR}/${DESIGN_NAME}.mapped.v
# For DDC
read_ddc -i ${RESULTS_DIR}/${DESIGN_NAME}.mapped.ddc
# Or Milkyway
# read_milkyway -i -libname ${mw_design_library} -cell_name ${DESIGN_NAME}_DCT ${mw_reference_library}
# Set implementation design
set_top i:/WORK/${DESIGN_NAME}
# Or for Milkyway
# set_top i:/${mw_design_library}/${DESIGN_NAME}
# Configure constant ports. When using the Synopsys Auto Setup mode,
# the SVF file will convey information automatically to Formality about
# how to disable scan.
# Otherwise, manually define those ports whose inputs should be assumed constant
# during verification.
# Example command format:
# set_constant -type port i:/WORK/$DESIGN_NAME/<port_name> <constant_value>
# Match compare points and report unmatched points
match
report_unmatched_points > ${REPORTS_DIR}/${DESIGN_NAME}.fmv_unmatched_points.rpt
# Verify and report
if {![verify]} {
save_session -replace ${REPORTS_DIR}/${DESIGN_NAME}
report_failing_points > ${REPORTS_DIR}/${DESIGN_NAME}.fmv_failing_points.rpt
report_aborted > ${REPORTS_DIR}/${DESIGN_NAME}.fmv_aborted_points.rpt
# Timestamp
sh date
# Terminate
exit
mips32.s0.tcl: (constraints)
echo "** LOG(mips32.s0.tcl): SCENARIO (S0)"
set PERIOD 10 ;# 10 ns clock period -> 100 MHz max
set INPUT_DELAY 1.0
set OUTPUT_DELAY 1.0
set CLOCK_LATENCY 1.5
set MIN_TO_DELAY 1.0
set MAX_TRANSITION 0.5
# Preserve all heirarchy (set to true when RTL is in development)
set NO_UNGROUP false
echo "** LOG(mips32.s0.tcl): S0 PERIOD: ${PERIOD}"
# Clock basics
# Set clk period
create_clock -name "clk" -period $PERIOD [get_port clk]
# Set clk latency: time it takes for clk signal to get from source to FF sync pin.
set_clock_latency $CLOCK_LATENCY [get_clocks clk]
# Set clk uncertainity (jitter/skew): maximum time difference between two pins on
# a chip receiving the same clk signal
set_clock_uncertainty 0.3 [get_clocks clk]
# Set clk transition: time for clk to go 0->1 or 1->0
set_clock_transition 0.4 [get_clocks clk]
# Grouping clk/inputs/outputs for better optimization
group_path -name CLK -to clk
group_path -name INPUTS -through [all_inputs]
group_path -name OUTPUTS -to [all_outputs]
# Set I/O names
set INPUTPORTS [remove_from_collection [all_inputs] [get_ports clk]]
set OUTPUTPORTS [all_outputs]
# Set delay constraints on I/O boundaries
set_input_delay -clock "clk" -max $INPUT_DELAY $INPUTPORTS
set_input_delay -clock "clk" -min $MIN_TO_DELAY $INPUTPORTS
set_output_delay -clock "clk" -max $OUTPUT_DELAY $OUTPUTPORTS
set_output_delay -clock "clk" -min $MIN_TO_DELAY $OUTPUTPORTS
# Set the load and driving cell
set REFLIB [file rootname $TARGET_LIBRARY_FILES]
set DFFCELL "DFFARX1"
set DFFCELL_IN_PIN "D"
set DFFCELL_OUT_PIN "Q"
# Set maximum load to be 5X the input capacitance of a DFFARX1 cell
set_load [expr 5 * [load_of $REFLIB/$DFFCELL/$DFFCELL_IN_PIN]] [all_outputs]
# Set a DFF flip flop as the driving cell for all inputs (pipelined stages)
set_driving_cell -library $REFLIB -lib_cell $DFFCELL -pin $DFFCELL_OUT_PIN [all_inputs]
# Driving cell does not drive clk so remove it
remove_driving_cell [get_ports clk]
# Set maximum transition time of any net in design to be 1 ns.
set_max_transition $MAX_TRANSITION [current_design]
# Set the maximum capacitance on any net in the design to be 1 pF.
set_max_capacitance 1.0 [current_design]
# Set maximum fanout of any net in the design
set_max_fanout 20 [current_design]
# Minimize the area
set_max_area 0
Added after 45 minutes:
# Timestamp
sh date
# Design Compiler Reference Methodology Script for Top-Down Flow
# Add any additional variables here
# No additional flow variables are being recommended
# Setup for Formality verification: SVF should always be written to allow
# Formality verification for advanced optimizations
# Setup SAIF name mapping database: Include an RTL SAIF for better power
# optimizaiton and analysis
saif_map -start
# Read in the RTL design: read in either RTL source files or an elaborated
# design (DDC)
define_design_lib WORK -path ./work
analyze -format verilog ${RTL_SOURCE_FILES}
elaborate ${DESIGN_NAME}
write -hierarchy -format ddc -output ${RESULTS_DIR}/${DESIGN_NAME}.elab.ddc
# OR read an elaborated design from the same release. Using an elaborated design
# from an older release will not give best results.
# read_ddc ${DESIGN_NAME}.elab.ddc
# current_design ${DESIGN_NAME}
# Resolve design/modules references by linking design to logical libraries
link
# Apply logical design constraints
source ${DESIGN_NAME}.s0.tcl
# We can enable analysis and optimization for multiple clocks per register. To
# use this, we must constrain to remove false interactions between mutually
# exclusive clocks. This is needed to prevent unnecesasry analysis that can result
# in a significant runtime incrase with this feature enabled.
# For mips32, it is unnecessary since we have a single clock.
# set_clock_groups -physically_exlucive | -logically_exclusive | -asynchronous \
# -group {CLKA, CLKB} -group {CLKC, CLKD}
# set timing_enable_multiple_clocks_per_reg true
# Apply operating conditions on top level. Set min/max for delay analysis and
# typical for normal usage.
set_operating_conditions -max WORST \
-max_library [file rootname $max_library] \
-min BEST -min_library [file rootname $min_library]
set_operating_conditions TYPICAL
# Create default path groups: separating these paths can help improve optimization.
# Remove these path group settings if user path graoups have already been defined.
set ports_clock_root [get_ports [all_fanout -flat -clock_tree -level 0]]
group_path -name REGOUT -to [all_outputs]
group_path -name REGIN -from [remove_from_collection [all_inputs] $ports_clock_root]
group_path -name FEEDTHROUGH -from [remove_from_collection [all_inputs] $ports_clock_root] -to [all_outputs]
# Power optimization
# Clock gating setup
# Default clock_gating_style suits most designs. Change only if necessary.
# set_clock_gating_style ...
# Clock gate insertion is now performed during compile_ultra -gate_clock
# so insert_clock_gating is no longer recommended at this step.
# For better timing optimization of enable logic, clock latency for
# clock gating cells can be optionally specified.
# set_clock_gate_latency -clock <clock_name> -stage <stage_num> \
# -fanout_latency {fo_range1 latency_val1 fo_range2 latency_val2 ...}
# Apply power optimization constraints
# Include a SAIF file, if possible, for power optimization. If a SAIF file
# is not provided, the default toggle rate of 0.1 will be used for propagating
# switching activity.
# read_saif -auto_map_names -input ${DESIGN_NAME}.saif -instance < DESIGN_INSTANCE > -verbose
# Remove set_max_total_power power optimization constraint from scripts in 2008.09
# Enable both of the following settings for total power optimization
set_max_leakage_power 0
# set_max_dynamic_power 0
# Setting power constraints will automatically enable power prediction using clock tree estimation.
# If you are not setting any power constraints and you still want to report
# correlated power, you can use the following command to turn on power prediction.
set_power_prediction true
# Apply physical desigin constraints
# Optional: Floorplan information can be read in here if available.
# This is highly recommended for irregular floorplans.
# Floorplan constraints can be extracted from DEF files using
# extract_physical_constraints OR provided from Tcl commands.
# DEF is the recommended input format to maximize the use of the latest
# floorplan read capabilities of Design Compiler topographical mode.
# Specify ignored layers for routing to improve correlation
# Use the same ignored layers that will be used during place and route
if {${MIN_ROUTING_LAYER} != ""} {
set_ignored_layers -min_routing_layer ${MIN_ROUTING_LAYER}
if {${MAX_ROUTING_LAYER} != ""} {
set_ignored_layers -max_routing_layer ${MAX_ROUTING_LAYER}
report_ignored_layers
# If the macro names change after mapping and writing out the design due to
# ungrouping or Verilog change_names renaming, it may be necessary to translate
# the names to correspond to the cell names that exist before compile.
# During DEF constraint extraction, extract_physical_constraints automatically
# matches DEF names back to precompile names in memory using standard matching rules.
# Modify fuzzy_query_options if other characters are used for hierarchy separators
# or bus names.
# set_fuzzy_query_options -hierarchical_separators {/ _ .} \
# -bus_name_notations {[] __ ()} \
# -class {cell pin port net} \
# -show
# Note: The -site_row or -pre_route options are not needed to extract this info
# from the DEF file. These are extracted automatically and saved in DDC.
# Only use these options if you want this info to be included in the
# ASCII output from "extract_physical_constraints -output".
if {[file exists [which ${DESIGN_NAME}.def]]} {
extract_physical_constraints ${DESIGN_NAME}.def
# OR
# For Tcl constraints, the name matching feature must be explicitly enabled
# and will also use the set_fuzzy_query_options setttings. This should
# be turned off after the constraint read in order to minimize runtime.
# set fuzzy_matching_enabled true
# source -echo -verbose ${DESIGN_NAME}.physical_constraints.tcl
# set fuzzy_matching_enabled false
# Note: Include the -site_row or -pre_route options with either
# write_physical_constraints or report_physical_constraints if you also
# want to include these in the ASCII output files. Site rows and pre-routes
# are automatically extracted from the DEF and saved in the DDC even if these
# options are not specified.
# You can save the extracted constraints for fast loading next time.
# write_physical_constraints -output ${DESIGN_NAME}.physical_constraints.tcl
# Verify that all the desired physical constraints have been applied
report_physical_constraints > ${REPORTS_DIR}/${DESIGN_NAME}.physical_constraints.rpt
# Apply additional optimization constraints
# Prevent assignment statment in the Verilog netlist
set_fix_multiple_port_nets -all -buffer_constants
# Insert level-shifters on all clocks
set auto_insert_evel_shifters_on_clocks all
# Preserve subdesign interfaces
# NOTE; when design is matured, we can turn this off so it does heirarchical
# optimization by pushing subdesign constants (pins connected to logic 0/1) to
# the external environment and optimizing that.
#set compile_preserve_subdesign_interfaces true
# Write out all unconnected pins in verilog netlist
set verilogout_show_unconnected_pins true
# Fix hold-time violations on clock by slowing down data signals
set_fix_hold [get_clocks clk]
# Fix timing violations if not in topographical mode
if {![shell_is_in_topographical_mode]} {
set compile_top_all_paths true
# Compile the Design
# Recommended Options:
# -scan
# -gate_clock
# -retime
# -timing_high_effort_script
# -area_high_effort_script
# -congestion
# -num_cpus
# Use compile_ultra as your starting point. For test-ready compile, include
# the -scan option with the first compile and any subsequent compiles.
# Use -gate_clock to insert clock-gating logic during optimization. This
# is now the recommended methodology for clock gating.
# Use -retime to enable adapative retiming optimization for further timing
# benefit without any runtime or memory overhead.
# The -timing_high_effort_script or the -area_high_effort_script option
# may also be used to try and improve the optimization results at the tradeoff
# of some additional runtime.
# The -congestion option (topographical mode only) enables specialized optimizations that
# reduce routing related congestion during synthesis and scan compression insertion
# with DFT Compiler. Only enable congestion optimization if required.
# This option requires a license for Design Compiler Graphical.
# Use -num_cpus to enable multi-core optimization to improve runtime. Note
# that this feature has special usage and license requirements. See the following
# article for more info: https://solvnet.synopsys.com/retrieve/024947.html
# Use the "-check_only" option of "compile_ultra" to verify that your
# libraries and design are complete and that optimization will not fail
# in topographical mode. Use the same options as will be used in compile_ultra.
compile_ultra -check_only
if {$NO_UNGROUP} {
compile_ultra -gate_clock -area_high_effort_script -no_autoungroup -retime
} else {
compile_ultra -gate_clock -area_high_effort_script -retime
# Write Out Final Design and Reports
# .ddc: Recommended binary format used for subsequent Design Compiler sessions
# Milkyway: Recommended binary format for IC Compiler
# .v : Verilog netlist for ASCII flow (Formality, PrimeTime, VCS)
# .spef: Topographical mode parasitics for PrimeTime
# .sdf: SDF backannotated topographical mode timing for PrimeTime
# .sdc: SDC constraints for ASCII flow
change_names -rules verilog -hierarchy
# Check the design for consistency
check_design
# Write and close SVF file and make it available for immediate use
set_svf off
# Write out design
write -format ddc -hierarchy -output ${RESULTS_DIR}/${DESIGN_NAME}.mapped.ddc
write -f verilog -hierarchy -output ${RESULTS_DIR}/${DESIGN_NAME}.mapped.v
# Write out design data
# Note: Include the -site_row or -pre_route options with write_physical_constraints
# if you also want to include these in the ASCII output files. Site rows and pre-routes
write_physical_constraints -output ${RESULTS_DIR}/${DESIGN_NAME}.mapped.physical_constraints.tcl
# Write parasitics data for static timing analysis
write_parasitics -output ${RESULTS_DIR}/${DESIGN_NAME}.mapped.spef
# Write SDF back annotation data from DCT placment for static timing analysis
write_sdf ${RESULTS_DIR}/${DESIGN_NAME}.mapped.sdf
# Do not write out net RC info onto SDC
set write_sdc_output_lumped_net_capacitance false
set write_sdc_output_net_resistance false
write_sdc -nosplit ${RESULTS_DIR}/${DESIGN_NAME}.mapped.sdc
# If SAIF is used, write out SAIF name mapping file for PrimeTime-PX
saif_map -type ptpx -write_map ${RESULTS_DIR}/${DESIGN_NAME}.mapped.SAIF.namemap
# Generate final reports - qor, timing, area, congestion, power, clock gating
report_qor > ${REPORTS_DIR}/${DESIGN_NAME}.mapped.qor.rpt
report_timing -nworst 10 -transition_time -nets -attributes -nosplit > ${REPORTS_DIR}/${DESIGN_NAME}.mapped.timing.rpt
report_hierarchy -nosplit > ${REPORTS_DIR}/${DESIGN_NAME}.mapped.hierarchy.rpt
report_resources -nosplit -hierarchy > ${REPORTS_DIR}/${DESIGN_NAME}.mapped.resources.rpt
report_constraint > ${REPORTS_DIR}/${DESIGN_NAME}.mapped.constraints.rpt
report_area -physical -nosplit > ${REPORTS_DIR}/${DESIGN_NAME}.mapped.area.rpt
# report_congestion (topographical mode only) reports estimated routing related
# congestion after topographical mode synthesis. This command requires a
# license for Design Compiler Graphical.
# report_congestion > ${REPORTS_DIR}/${DESIGN_NAME}.mapped.congestion.rpt
} else {
report_area -nosplit > ${REPORTS_DIR}/${DESIGN_NAME}.mapped.area.rpt
# Use SAIF file for power analysis
#read_saif -auto_map_names -input ${DESIGN_NAME}.saif -instance < DESIGN_INSTANCE > -verbose
report_power -nosplit > ${REPORTS_DIR}/${DESIGN_NAME}.mapped.power.rpt
report_clock_gating -nosplit > ${REPORTS_DIR}/${DESIGN_NAME}.mapped.clock_gating.rpt
# Write the shell command script to save current settings
write_script -out ${RESULTS_DIR}/${DESIGN_NAME}.script
# Write out Milkyway Design for Top-Down Flow
# NOTE: This should be the last step in the script
write_milkyway -overwrite -output ${DESIGN_NAME}_DCT
# Timestamp
sh date
# Terminate
exit
would you please atach the script with files, and we can download it easily.
You dont use operand isolation for power optimization, why?
Hello Guys,
I am supposed to create a Milkyway design library.
I don't know ewactly if I have a Milkyway Reference Library on the network.
I do have the synopsys libs, dbs, tf..., but don't know what a Milkyway Reference Library looks like.
Is it a file or a directory, if so whar kind of file are in it?
Could someione tell me what I am actually looking for?
Thank you
Dan
Operand isolation will give you some overhead in terms of area, and it might impact frequency. That might be the reason...
The script must be matched the project!
If ONLY learn, you may use the synopsys training material.
Good lucky
Flow snps DC RM script.. that will more help
    V
Re: compile_ultra multiple times
common-setup.tcl:
# Set Design Path
# Target libraries
# Symbol library
# design.
dc-setup.tcl
# best results.
set LOG "syn-log"
file mkdir ${LOG}
# RC extraction
-hier_separator {/}
} else {
check_library
dc.tcl:
# Timestamp
sh date
# out-of-the-box.
# Read in libraries
# For verilog
# For DDC
# Or Milkyway
# Or for Milkyway
match
# Verify and report
if {![verify]} {
# Timestamp
sh date
# Terminate
exit
set INPUT_DELAY 1.0
# Clock basics
# Set clk period
# Set I/O names
# Minimize the area
set_max_area 0
# Timestamp
sh date
saif_map -start
# design (DDC)
link
# or bus names.
# -show
# OR
# -scan
# -gate_clock
# -retime
# -congestion
# -num_cpus
if {$NO_UNGROUP} {
} else {
check_design
set_svf off
# Write out design
} else {
# Timestamp
sh date
# Terminate
exit
Tahnx for uploading this script file i use you constraint file as a reference and when i give
set_load [expr 2 * [load_of $REFLIB/$DFFCELL/$DFFCELL_IN_PIN]][all_output] command i got following error
Error: value '2.98966_sel44' for option 'value' not of type 'float' (CMD-009)
Error: Required argument 'objects' was not found (CMD-007)
can you please explain me why i got this error how i correct it.
