C Code to send image from PC on ftp server using USB Modem
yousafzai82
Member level 4
Pakistan
Hi all
I need to write a c code to send an image from PC to the ftp server on using USB Modem. I am really stuck from where to start??
Is it like this i will have to print AT commands followed by the data image on the usb port.
Someone please help me in this regards.
Zahoor Ahmad
Re: C Code to send image from PC on ftp server using USB Mod
The solution can be from very simple to fairly complicated depending upon the environment available and restrictions imposed.
In its simplest form, let's assume that you are going to write the program for
1)Windows or Linux OS (not an embedded standalone app)
and
2)The modem is a standard commerical modem (Already detected by your OS and driver installed)
3) And you have ftp client available on your system
Then
all you need to do is to call that from your program with appropriate paramaters.
and
I am sure about these points. I am able to connect through hyperterminal using commands
at
OK
at+cgatt=1
OK
at+cgdcont=1,"ip","internet","58.181.105.95",0,0
OK
at+cgdata="ppp",1
CONNECT
But when i select "send file" from hyperterminal window, the window is closed after giving the message "connection time out", i would like to mention that i am using teltonika E12 Modem..
Another problem is that how i can send these at commands on USB Port using C coding, please give me some idea?????
It's good that your setup is functional. And the hint is already there
"all you need to do is to call that from your program with appropriate paramaters. "
You are using hyperterminal so you'll probably be on a windows system. You will just need to learn how to run an executable from a C program.
Hint: ShellExecute
From your description, you want to work on application layer so you don't need to bother to USB at bus level. If that's the only active modem on your system, commands will automatically go through that.
One problem i am facing is where should i define the port number. Like i have defined target ip but i don't know how to define port number??????????
FTP uses port 21 and you shouldn't need to explicity set it for client if the server is listening ont the default port.
