How to build a voltmeter using Pic16f887?
Re: Volt Meter Pic16f887
sahu said:
pl help any bod for 16f676 voltmeter
Your voltage range...(If 0 to 5v)
then just connect it to the any of the ADC pins of your MC. if it is above 5v use simple resis. network.
Good Luck.
I use flowcode for programming.
Which PIC do you want to use?
How many inputs do you want?
Do you want overflow dispalys?
I can provide ASM code for this so long as it is not used for commercial purposes.
1- 16F676 BASED
2- 3 DIGIT 7SEG.
3- 1 I\P RANG 0 TO 500 V AC
Hi sahu,
here is the circuit for you i am using this for upto 300v , if you want you can reduce the 1.5k resistor, i traced the circuit from voltmeter from market and i make the code for that
rajudp said:
Hi sahu,
THANK U mr rajudp
hi
here is the PCB design for the same
program softwarefor887Voltmeter
dim LCD_RS as sbit at RB4_bit
    LCD_EN as sbit at RB5_bit
    LCD_D4 as sbit at RB0_bit
    LCD_D5 as sbit at RB1_bit
    LCD_D6 as sbit at RB2_bit
    LCD_D7 as sbit at RB3_bit
    LCD_RS_Direction as sbit at TRISB4_bit
    LCD_EN_Direction as sbit at TRISB5_bit
    LCD_D4_Direction as sbit at TRISB0_bit
    LCD_D5_Direction as sbit at TRISB1_bit
    LCD_D6_Direction as sbit at TRISB2_bit
    LCD_D7_Direction as sbit at TRISB3_bit
dim ADCResult as longword
dim voltage as word[5]
dim display as string[5]
sub procedure GlobInit
    ANSEL = 1
    ANSELH = 0
    TRISA = 1
    TRISB = 0
    PORTB = 0
    LCD_Init()
    LCD_Cmd(_LCD_CLEAR)
    LCD_Cmd(_LCD_CURSOR_OFF)
    LCD_Out(1, 1, "Voltage:")
    LCD_Chr(1, 16, "V")
    display[1] = "."
end sub
main:
     GlobInit
     while true
           ADCResult = (ADC_Read(0) * 500) >> 10
           voltage[0] = ADCResult div 100
           voltage[1] = (ADCResult div 10) mod 10
           voltage[2] = ADCResult mod 10
           display[0] = voltage[0] + 48
           display[2] = voltage[1] + 48
           display[3] = voltage[2] + 48
     vout:
           LCD_Out(1, 10, display)
           delay_ms(50)
     wend
end.
Here what does this line mean to do
 ADCResult = (ADC_Read(0) * 500) >> 10?
    ANSEL = 1
    ANSELH = 0
    TRISA = 1
    TRISB = 0
    PORTB = 0
    LCD_Init()
    LCD_Cmd(_LCD_CLEAR)
    LCD_Chr(1, 16, "V")
    display[1] = "."
end sub
main:
     GlobInit
     while true
     vout:
           delay_ms(50)
     wend
end.
can u proved it code in asm formet & hex with pic16f676 lcd & 3 digit 7 segment display.
rajudp said:
hi
What is the voltage into the PIC for this design? Which input are you using for the signal and what are the output connections for the display?
I am unsure how to download your design to code it into my flowcode for asm/hex files.
RA0 for input to ADC and RA1 as reference volt for ADC . the 5.1 volt zener will keep the pic supply to 5.1v but it will get drop when LED is on
Re: Volt Meter Pic16f676
pl replly me about Volt Meter Pic16f676 source code or hex code.
how ı take out for control,on 14,5v.please,help.
if you want to measure 14.5 v use simple resister divider that 1/3 of volt to pic (less than 5v ) you can give the ADC reference to vcc
rajudp said:
Hi sahu,
I have a few questions regarding these resistors, how much power dissipates on them or which resistors are these power resistors and how big are the usual currents though them.
thx
the normal resistors are in 1/4watt and R1 ( 100ohm) is 2w
Re: How to build a voltmeter using Pic16f887
Hai All,
Try this project DVM using LCD and PIC.....so simple to make...but only measure 1.5 v DC to 20 v DC.
see you again........
Manoj Soorya/manoj madhavan
  • DVM.rar
Hai All,
i want low\hi volt alarm as drive relay.
10.5 volt as low
15 volt as hi how can set it ? pl help me...
Pls give flowcode file , i dont know asm and c
