how to connect ir2110
gowri.tatini
Newbie level 1
hi
plz tell me how to connect ir2110 to h bridge invereter using mosfets.we connected as per the data sheet for ir2110 connecting to only two mosfets.but ir2110 is getting heated.is that correct.we are using 230v supply to mosfets .so what r the capacitance n resistance values i can keep in the circuit given in datasheet ir2110
.thanks for reading this
hi
upload a pic from the schematic of your work
the ir2110 hasn't problem
what do U do for supplying of 2110 the heat almost is because wrong supply voltage
for 230v it's better to use ir2113 "it's 600V"
for H bridge U must make a true square signal in 50 hz for to IR2110 & put them in 2 side of a H bridge
attention use a flip flop to have true signal in input of ir2110 , f it's wrong burned your mosfets
i am wondering if anyone can help me.
Am building an high frequency switching inverter using the tl494(20khz),and using a H bridge,
can anyone assist me on how the H bridge converts dc back into ac, i mean how do i do this, and how do i get 50hz from this, many thanks
12vdc.....tl494...push-pull mosfets....transformer...bridge rectifier...h bridge...lc filter..
what i need to know is how to switch 2 on and 2 off at same time resulting in ac 220v ,
And how do i get 50hz, if u know
what i mean
this is a mod-sine wave btw
many thanks
    V
