Tahmid
Advanced Member level 6
- Joined
- Jun 17, 2008
- Messages
- 4,756
- Helped
- 1,798
- Reputation
- 3,588
- Reaction score
- 1,656
- Trophy points
- 1,413
- Location
- Berkeley, California
- Activity points
- 30,586
Hi all,
I have a 12V 7.5Ah sealed maintenance-free lead-acid battery lying around. Till now, I've been charging it for 14 hours. Now I want to charge it within 4 hours or quicker if possible without damaging the battery too quickly.
Here's what I've got:
•To charge the battery quickly I need to provide at around 15v. My question, if I provide 15v to the battery, will it automatically charge quickly?
•For controlling the voltage, I am thinking of using PIC16F873A/PIC18F1320. There is a 25v dc supply, which I will convert to 15v with PWM and MOSFET. I will sense the current flowing to the battery and when current falls below 0.01C, I will assume charging is done and decrease PWM duty cycle to supply around 13.2V.
Is what I have stated correct and sufficient for charging it quickly? Don't worry about the programming, I think I can manage that. I just want advice about the required hardware.
If not, what should be done. I've had a look at some battery technical handbooks from different manufacturers where I've read about charging at 2.4v/cell and 0.4C current for fast charge.
Now, I'm going off to sleep. I'll be waiting for your responses, ideas and input.
Thanks everyone for any input.
