Level shifter circuit :
raduga_in
Full Member level 4
India's Silicon Vally
level shifter circuit
Hi PPl !!
I am looking for a CMOS circuit which will convert CMOS 3.3 V supply logic
to CMOS 1.2 V supply logic. Can anybody help me out in this regard.
TIA
Raduga
level shifter
You are not very clear of what you need but you could try the Texas Instruments AVC bus transceivers family.
level shift circuit
Thanks xvibe !!
But let me rephrase myself, I am looking for a trasistor level circuit which would act as an interface between a 3.3 V supply CMOS logic to 1.2 V CMOS logic circuitry.
Raduga
1.2v from 3.3v circuit
Raduga
If the 1.2V transistors can stand a gate-source (and gate-bulk) voltage of 3.3V (resp. -2.1V), you can directly connect the 3.3V logic output to the 1.2V logic input. If not, the easiest solution is a (high-ohmic, depending on bit rate) voltage divider. For higher data rates, a 3.3V nfet (double or triple cascaded) source follower (or npn Darlington emitter follower + diode) would be an acceptable solution.
For the other direction, use the standard level shifter circuit (1.2V inverter controling a 3.3V 4T-FF (similar to a 1bit SRAM cell).
Cheers, erikl
level shifter circuits
You could just use a buffer made with 3.3V transistors in the 3.3V domain followed by an inverter made with 3.3V transistors in the 1.2V domain followed by an inverter made with 1.2V transistors in the 1.2V domain.
hi
i want design a level shifter to level voltage 12 and 0 convert to 12and 0.plz help me.
