plane wave+reflection with the use of field monitors
cristal86
Newbie level 3
plane wave reflection cst
HI,
Is it possible to see for a plane wave th reflected plane wave with the use of field monitors?
reflected wave electric field
cristal86 said:
HI,
electromagnetic wave is invisible, you can not see it....
but probably you think some software, can you tell me what ? CST MWS ?
cst reflected field plane wave
Thanks.I use CST but where can i find a tutorial or helps where i can read that the reflected wave with plane wave can't be seen with field monitors?
cst refelcted wave
Only reflected field you can not see (I think), you can see only all field = incident + reflected. May be try in field monitors "Time" and you can see field in time. Can you tell me about your project?
Re: plane wave+reflection
Sorry I wanted say the total electric field(not only the reflected wave).
The project is a periodic structure and I have a plane wave which goes towards it with angle=60° but with the monitor i see only the plane that strike the structure but i don't see the reflected wave.
Added after 1 minutes:
I should see a reflected wave.
I have even listed that plane wave in cst studio don't let you to see reflected plane wave.
I have even listed that plane wave in cst studio don't let you to see reflected plane wave.[/quote]
hmm, i have not even listed this, and I think, that is crap :) .May be your reflected plane is very "small" and you cant see it..... may be. The best will be, if you can send me your project.
