maheshkuruganti
verilog pulse generator
I want to know how to generate a Pulse of Fixed Duration in Verilog on application of a Trigger.I wrote a code but it is not working.Can anyone help ??
Thank You Very Much.
`timescale 1ns / 1ps
// Company: Allied Electronics Co.
// Engineer: K.V.Mahesh
// Create Date: 00:38:39 05/24/2009
// Design Name: Dual Pulse Generator
// Module Name: Pulse_Gen
// Project Name: Dual Pulse Generator
// Target Devices: XC3S400A FT256 -4 Speed Grade
// Tool versions: 10.1i
// Description: This is a Pulse Generator Module that generates a Pulse on the negative edge
// of the trigger signal.The Pulse_Width word is from the main module.
// Dependencies: Main.v
// Revision: v0.6
// Additional Comments:
module Pulse_Gen(
input Trigger,
output Pulse_Out,
input [31:0] Pulse_Width,
input Clock
//Register Declaration. //
reg[31:0] PWidth; //To Hold Pulse Width Word.
reg Out_Enable; //For Triggering Purposes.
reg Pulse=0,Done;
//Triggering //
always@(posedge Trigger)
begin
Out_Enable=~Out_Enable;
end
//Actual Pulse Generation Section //
always@(posedge Clock)
begin
if(PWidth==Pulse_Width)
begin
PWidth<=32'h00000000;
Pulse<=1'b0;
end
else
begin
PWidth<=PWidth+1;
Pulse<=1'b1;
end
end
assign Pulse_Out=Pulse;
endmodule
