jonna
Newbie level 1
cdsdoc
Hi everyone,
I have installed cadence IC 610 in Redhat ES 5,
When i try to start cdsdoc, i get the following error :
"error while loading shared libraries: libpthread.so.0: cannot open shared object file: No such file or directory
although libpthread.so.0 is in /lib directory, (/lib is set into $path already)
Anyone can help me out this trouble ?
tHank you
Added after 13 minutes:
problem solved! for anyone who get this problem.
locate cdsdoc, then comment the line
export LD_ASSUME_KERNEL=2.2.5
Added after 33 minutes:
Hi, I still get problem with cdsdoc. When trying to read any document, i get the error
fail to start CDSDOC server obServer
in the console
xxx/bin/obServer: error while loading shared libraries: libnsl.so.1: cannot open share object ...
An error that's pretty similar to error above. But I could not edit obServer file, it's a binary file. Any suggestion ?
Hi everyone,
tHank you
in the console
