Designing a high voltage/wattage SMPS
vaibhav.k
India
Hi Friends
I want some help regarding high voltage/wattage SMPS
SMPS rating are 48V/200W and 48V/1000W>please send me any reference designs and some details for study.Also tell me some study links
Thanks in advance
Vaibhav
smps rating
Hi friends
please help
me
i want design 48V/3.5A battery chargers send me some study links or some reference designs
half bridge transformer design amazon
For the 200W use a half bridge forward converter and for the 1000W one use a full bridge forward converter. A flyback design is just possible for the 200W but this is on the limit so I would not recommend it for a first try.
Start here for downloading the magnetics design software:
http://www.mag-inc.com/
Then follow this link or the link marked magnetics builder on the Magnetics Inc homepage for reference circuit designs and design software.
I hope this helps.
There is quite a lot to switch mode PSU designing, so expect a few failures early on and be very very careful as part of a SWMP is mains live, use an isolation transformer for the initial test stage if you do not want to risk death.
I would also recommend that you buy a book such as Practical Switchmode Power Supply Design by Marty Brown.
Good luck
Bob.
    vaibhav.k
how wattage of a smps can be increased
Hi Bob
Thank u very much
I will definitely take care in all aspects
Could u please send me any link for Practical Switchmode Power Supply Design by Marty Brownas i am unable to get hard copy in local market.
    vaibhav.k
48v smps design
Hi Bob could u tell me difference between Two-Switch Forward Converter and half bridge forward converter.Or both are same.
higher watt smps with top ic
hey vai
both topologies are diffarent .....they are so many diffarances
darla
    vaibhav.k
High wattage SMPS
DrBob13 had mentioned about powerEsim, it new site is:
https://www.powerEsim.com/
You can go there to find both Two-Switch Forward Converter and half bridge forward converter and do simulation there.
Hopes it helps.
