how to generate clock signal for ADC & DAC?
liletian
Full Member level 6
how to generate a clock signal
Hi Guys
What is the normal way to generate clock signal for ADC? where can I find a complete ADC design circuit where clock signal generation on? I will think to generate clock signal using inverter oscillator and use digital logic to generate other waveform based on this, any suggestions?
how to generate clock for adc
amol_shah said:
which ADC are you using?
you can use a 555 ckt or you can give the clk through the controller itself
here is a link for interfacing ADC 0808 to 8051 controller, the clock is provided by the controller itself
https://www.dnatechindia.com/index.php/Tutorials/8051-Tutorial/Interfacing-ADC0808-To-8051.html
I want to make the clock myself so I can integrated it in one chip? I would like the ADC frequecny up to 10MHZ. Any suggestions?
generate clock
You'd be best off using an external clock generator, even just a simple oscliator.
Generating clocks can be a noisy business
adc clock generation
We use pll generate the ADC clock usual. There is the PLL in your product system usual. Did you only design a ADC and it is not in some product ?
adc and dac interface with 8051 tutorial
Yes, we do have a PLL in the loop, but the signal I have in PLL is from a inverter oscillator at 2.2GHZ, and the signal I want is a signal at 5-10Mhz and a signal 2.195MHZ, is it possible? should I use digital counter to generate the signal? If possible, could you please decribe it in details?
Thanks a lot
Let digital engineer help you. you tell them your timing, they will give you the timing that you needed. Do this timing is easy for a digital engineer.
Can you tell me how to do it? I am going to be partly digital guy.
If you are using microcontroller then you can probably connect your ADC/DAC to the SPI interface of MCU if your ADC/DAC can support SPI interface. Alternatively, you can also use polling method with the normal I/Os to generate clock.
Hi Liletian:
I think you know your ADC&DAC timing clearly. Tell your digital engineer the timing spec, you'd better draw a detail timing diagram for digital engineer. I am not digital engineer, I only tell my request to digital engineer in our design team. the timing of digital part generate by digital synthesis.
Added after 7 minutes:
The input of digital block is the PLL's output. I think the digital engineer generate the low speed clock by digital divider.
