need discription or abstract of any project based on 8051
rizwanspirit
Member level 4
8051.com
hi every one
please any one give me a sort discription or abstract of any project based on8051.
Re: 8051
YOu can find n number of projects if you google for 8051 designs.
Re: 8051
As i m new in mcu field and do not know much about these. i found very projects regarding 8051 but the mcu used is not 8051 it is AT89C2051 ,AT89S52 or any other similar mcu I want to know that these mcus fall in 8051 or these are independent mcus.
Re: 8051
assalammualaikum...
here i the best web that i can give
you can have some microcontroller based project
Re: 8051
These are the independent MUs of family 8051. Why dont you study 8051 from Makanzi?
Re: 8051
those are the same mcu, AT89S52 is still inherit 8051 (as the AT89C2051 too, but with fewer pins), more powerfull though.
    rizwanspirit
Re: 8051
ckshivaram said:
can you tell me what is this 8051.com
I think there is no website by that domain
maybe he meant it was 8052.com 8)
Re: 8051
This is a application of MCU 8951 (8051 family), you can see and repair it for your application.[/img]
    rizwanspirit
Re: 8051
slam
All of these controllers belong to same family,same core ,but different features,
for example 8051 contains rom for program memory,while 89c51 is flash based,u can reprogram, c reffers to cmos technology, similarly 89c52 is the version with extended memory ,and additional timer,and 89c2051 is the 20 pin version,with some limitations,also 89s52 is the one with serial programming facility using spi(In System Programmable ISP) ,do read datasheet or search on google for exact details lots of example for each one available
shakeel
    rizwanspirit
Re: 8051
Whether it is AT89C2051, AT89S52 or any similar mcu, these all have same architecture
    rizwanspirit
Re: 8051
LCD interfacing tutorials 8051
u need any project with pcb and source code contact 9886357761 bangalore
8051
Those names are the generic names of 8051 family. Try to purchase Mohammed Ali Mazidi and Janice Gillespie Mazidi and Kenneth J.Ayala. These two books help u a lot. U can independently program if u master those books.
Pls,is 8051 the same as 89c51? Someone should please help me am confused with the two devices,i need explanations
