Cadence problem with RHEL 5.1
elbadry
Full Member level 6
Egypt
libxp.so.6 redhat cadence
Hi
I managed to install Cadence on RHEL 5.1
However, when I run icfb i get the message:
cannot find libXp.so.6
I was told elsewhere that this file is found in the package Xfree86. I downloaded and ran the package. However, when I reboot it seems that X-windows gets damaged. I cannot see anything (just a blank screen) and cannot login to Linux
Anybody faced such a problem?
redhat 5.1 libxp.so.6
Is the package version correct?
rpm libxp.so.6 redhat enterprise linux
How can I know the package version?
I am rather new to this. I didn't find the package in the source CD
setenv rhel
libXp.so.6 is a file found in Redhat Enterprise Linux 4. What I did was to copy the file and paste it in Redhat Enterprise Linux 5. I think the path was /usr/X11R6/lib. Oh yeah, you'll also have to place the path in your cshrc file.
    elbadry
redhat 5.1 + libxp.so.6
That's it?
Just copy the file in its place?
What exactly did you add to the cshrc?
rhel cshrc
If you install a newer or older RPM, your system could be damaged.
If you copy an older run time library to your system, you may need to set the environment variable LD_LIBRARY_PATH.
    elbadry
libxp so 6 redhat 5
So simply get the libXp.so.6 file from RHEL 4 and add it in the supposed path then add
setenv LD_LIBRARY_PATH /usr/X11R6
in the cshrc?
libxp.so.6 redhat 5
If you put libXp.so.6 in /usr/X11R6/lib, add fowllowing in ~/.cshrc:
setenv LD_LIBRARY_PATH /usr/X11R6/lib
    elbadry
installing cadence on rhel
If you put libXp.so.6 in /usr/X11R6/lib, add following in ~/.cshrc:
    elbadry
