Articles, ieee papers and books related to buck converter
ravitest
india
buck converter
This is the place for buck converter, here u can discuss all related to buck converter, here u can post articles, ieee papers,books related to buck converter.
Re: buck converter
Please try
motorola power supplies reference manual
many datasheets and application notes and design examples from Fairchildsemi.com and powerint.com
thse are most current and perhaps better than text book
Sarma
    ravitest
Re: buck converter
I recommend following books for the SMPS (converters etc) understanding and practical applications.
Power supply cookbook by Marty Brown
OR
Practical Switching Power Supply Design by Martin Brown
AND
Switchmode power supply handbook by Kieth Billings
    ravitest
Re: buck converter
The Book of Marty Brown is very good, after reading that the following books are very helpful
Switch-Mode Power Converters, Design and Analysis by Keng C. Wu
Switching Power Supplies A to Z By Sanjaya Maniktala
DC DC Converter By Fang Lin Luo
    ravitest
Re: buck converter
Please find good material on DC DC converter and buck.
Jitendra Dhasmana.
    ravitest
Re: buck converter
1.Fundamentals of Power Electronics
R. W. Erickson
2.Power electronics By Rashid
3.
    ravitest
Re: buck converter
I am attaching SMPS reference manual from ON semi (formerly Motorola), thanks to ON semiconductors.
  • smpsrm-d_1214.pdf
Re: buck converter
here is the paper for loop design
  • designing_stable_control_loop__ti__2577.pdf
Re: buck converter
This paper uses Simulink for loop design
Myber help
    ravitest
Re: buck converter
where can I find the book " Switch-Mode Power Converters, Design and Analysis by Keng C. Wu "
Thanks.
    ravitest
Re: buck converter
If you search on Maxim's website, you will find a very good tutorial for power suppliers:
    ravitest
buck converter
In fact, there are many many material and/or book or pdf about dc-dc. The key should base on your current level to choose the related material, step by step to improve.
    ravitest
Re: buck converter
I think the document is good for buck converter design in small signal modeling
    ravitest
buck converter
good topic,but my points is 0
    ravitest
Re: buck converter
here are some reference from TI
    ravitest
buck converter
en, good topic
    ravitest
buck converter
Good topic, thanks a lot!
    ravitest
buck converter
Good paper, thank all
    ravitest
buck converter
i've download it, it helps a lot ,thanks
    ravitest
