Ethernet controller interface with microcontroller
abdiyora
Junior Member level 1
ethernet controller interface
Hello Sir,
I want to interface Ethernet controller with microcontroller. I see some Ethernet controller in which SPI interface there. I have doubt, Is there different microcontroller have different Ethernet controller. Currently I have 89s52 microcontroller.
Can you suggest me which Ethernet controller is useful for me ?..
Thanking you...
With Regards,
Ankur
microcontroller interface ethernet controller
You can use ENC28j60 from Microchip
Cristi
wiz5100 datasheet
Is that possible to build an ethernet interface on a 8-bit mcu?
    abdiyora
w5100 chennai
I advice to you microchips mcu with ethernet controller. Microchip supplies a TCP/IP stack for free for that controller as well
    abdiyora
wiz5100 ethernet
Hello atmaca,
Thanks for reply & suggestion.But i still confused. Can you please tell me why i use microchip instead of 89s52 ?.. and why not use 89s52 ?..
Can you please send me any useful link for practical understanding...
Thank you for help me...
silabs microcontroller dealer
hi,
if you ae fond of 8051 u can choose controller from silabs. they also have a ethernet controller and they provide a TCP/IP stack compatible with their microcontroller.visit the web link given below for more info
www.silabs.com
india microcontroller ethernet
rajeshkumar123 said:
hi,
www.silabs.com
Hello rajeshkumar,
I see link but in which some development kit & some ethernet controller IC give. Is it available in india or not ?
I want to use microcontroller 89s52.
8051 ethernet controller
There is very hard to get hte ethernet controller IC since you are not a representative from a big company.
So, I still advice you to take other's member's suggestions. Use another type of MCU with built in Ethernet (Zilog, Microchip and ......)
If you are new comer in this field, visit www.edtp.com
wiznet ethernet chennai
You have a development kit available from silabs. I have bought the same ethernet kit for my educational use from silabs dealer in India. Read the book(link given below) on TCP/IP implementation on embedded device. Dont stick to AT89S52.
Initially in my college days i used the same AT89S52 . Silabs is much better than AT89S52 with lots of memory & pheripheral. It is also widely in the industry.
With Regards
S.Rajesh Kumar
    abdiyora
Hi rajeshkumar,
Can you please tell me which ethernet kit you bough and what prize ?..
Link which you give, ,
is currently not open...
hi,
the ethernet kit i bought from a local representative. It cost me around Rs.14000/-
The mouser pric is 120$ excluding shipping
https://www.silabs.com/tgwWebApp/public/web_content/products/Microcontrollers/en/EthernetDK.htm
Can u get me more details such as ur mail id & which city do u live in so that i can mail u on whom to contact .
try reading this ethernet design guide
with regards
s.rajesh kumar
Hi, rajeshkumar
It is too costly.I want to make ethernet controller for microcontroller.
If possible then give me the practical information related to this...
Some time ago I've found an interesting project at
If there are somebody trying to modify it?
The author seems to be busy with something else...
I see another atmel ic atmega88 or atmega168 which is used with ethernet controller ENC28J60.but here atmega 88/168 is not available.Instead of that atmega8 is available.I see both datasheet but not too much difference i find.
Can i used it for my application ?..
Thank you....
hi,
U can choose any controller but before choosing the controller please verify that u have enough support in terms of TCP/IP stack for the controller u use. You can build your own stack but it is not easy.
With Regards
S.Rajesh Kumar
Can I use microchip Ethernet controller ENC20J60 only with microchip microcontroller like PIC18F4620, etc or other microcontroller like Atmega88, 128, etc. ?..
Same as for, Atmel Ethernet controller CS8900 use only withAtmel microcontroller or other microcontroller....
What will be suitable for me ?.. Why ?..
Thank you...
Is there any programmer required for ethernet controller IC ?..
Hello Ankur,
the ENC28J60 requires additional software, the said IP stack, but no programmer. The software may me a reason, why the device isn't suited for your application, e. g. due to limited code space. I want to suggest a different chip: W5100 from Wiznet. www.wiznet.co.kr
This is an ethernet controller with embedded TCP/IP stack as known e. g. from GSM GPRS modems, including many functions you would need to implement in your software otherwise. It also has some restrictions, but most likely they don't count for your application. They also have good example applications.
I know, that Wiznet is represented in India, see Where to Buy on their homepage. There are also preceeding chips from Wiznet, but W5100 is probably best for new designs, a single-chip solution, offering different interfaces.
Regards,
Frank
I get IC ENC28J60.But i still not get 89S8252.
Can you please tell me at which in india i get this 89S8252 ic ?..
