Explanation of the sip stack (with links)
BAT_MAN
Member level 5
what is sip stack
I am doing my fyp on sip protocol analyzer to decode the header information of voip traffic for which sip is used and then store information on database but i have some queries can anybody help me with that
1 what is sip stack
does it translate from physical to application layer and how does different layers interact and how do we translate information
Re: Sip Stack
The Fusion Session Initiation Protocol (SIP) software suite is at the heart of Unicoi's Voice over Internet Packet (VoIP) offerings. Fusion SIP is a lightweight, transport-independent, text-based protocol designed for use in IP Phones, VoIP Gateways, and other IP-enabled products.
Fusion SIP source code is specifically designed for use in embedded devices, has a small footprint and is completely ROMable and re-entrant. The Fusion SIP stack provides a simplified API for easy integration with the application and transport stack (TCP/IP/UDP).
    BAT_MAN
