CB0703-PCB for "PICkit 2" DIY(Do It Yourself) fans
mcp6001 eagle
sadat007 said:
Hi, PICKIT2 LITE SE with 18F2553, the programming mode is working fine but when I try DEBUG mode from MPLAB it gives error
PK2Error0024: PICkit 2 was unable to establish a valid Vdd on the target (Attempted 5.00V - Read 0.00V)
Can any one help me to solve this?
sadat007
The PICkit2 can only supply about 100ma to the target. Try powering the target with a power supply.
pickit 2 clone datasheet
Dear blueroomelectronics
My target is running with its own supply. I can program the target but can not debug.
sadat007
how to program the pic18f46k20
Hi Friends
I made the original design as is in the manual of PICKIT2 from Microchip, but have some problem with the control of the voltage VDD, it can not control as well as say the manual, I found some problem in the input of the Opam MCP6001, I have changed the input from negative to positive, but still the hardware looks donot work OK, or there is some "mistake" in the circuit.........helpme please...
Of course this work normally with 5 volts (CAN CONTROL VDD on/off, But canot control voltage VDD from 2,5 to 5 volts), .....
One more, I tried to debug some ASM file, somes It Can do normally, but some others canot,
For example, I used ICD2 to debug some test and it does, but when I try with PICKIT2, it can not do....I think PICKIT2 is good as programmer, but still need some fix for debugger option as ICD2 .....
Jose
pickit 2 pcb board
no doubt on Microchip original design.
Would you please measure the voltage on your U2 Pin3 and Pin4?
pickit2 zif icsp
I see,
voltage in the input of the Opam is around 2.5 volts, and it change when I changed the voltage in the screen of Pickit2, in the output the voltage change, but no change acording the input, it change from 0 to 5, no step by step, it change as a comparator Opam.
And when I open software Pickit2 it say, check voltage at VDD, I tried to do some changes, changed the input of the opam, but still no work, .....
I donot know where is the problem,,,
Thank You
pickit2.hex
This sounds like the U2 got some issue.
THe MCP6001 and MCP6001U are chips with different pin-out, make sure it is connected correctly. Also pay a little attention on the power supply pin and ground pin.
If all above correct connection are verified. The last thing you can try is: get a new/good MCP6001U and replace the one on your board. the old one on your board may already be damaged.
unrecognized usb device pickit2
YES
There is so many diferent types of MCP6001, I changed too for a new one, but the result is the same, T tried with diferent configuration, but still no works......big problem, I like to be sure if the circuit of Microchip is good as is, or there is some trick....
Thank YOU
icd3 problem stop
THe MCP6001U sure is different than the MCP6001 on Pin1, 3 and 4.
No doubt on the PICkit2 schematic.
pcb clone pickit2 НА smd
HI
I AM USING IRLML6402, same as the circuit, I Have tested it and works ok, I got all original ICs and Transistors, as the design of Microchip, that my doubt about the circuit, .........I donot know what to do, finally, I will try to asemble in protoboard, but I haved checked the PCB, and it is good......:|
Jose
16f676 pickit 2 connection
if you can use the "PICKit2 programmer" software set the output voltage as 3.5V under trouble-shoot, and check the voltage on C8, you should get about 1.82V. Same voltage should be on Pin3 of MCP6001U.
If pin 3 is normal, please check the voltage on following resistors: R31, R26, R6 and R5.
Please take a volt measurement on both end of these resistors to GND.
We will see what you got. :)
Funny N.
pull up irlml6402
Hi friends
I found my mistake
I bought several IRLML6402, when I solder one, it was no same number, and it donot work like IRLML6402, when I changed with a new one, it works OK,
Thank You for your cooperation, now I will test with Low volatge PICs microcontrollers
Jose
pic18f debug pickit3
BB0703 has enhanced external power supply. and
Added after 3 minutes:
sadat007
Did you get any more good luck with the PIC18F2553 chip? It would be important for other people who also want to try your approach.
25lc256-i write protection circuit
Hi funnynypd,
Same debug problem with 18F2553, unfortunately I do not have 18F2550 to check if I am doing any thing wrong.
sadat007
    funnynypd
pic18f2480
Probably we can ask someone who has the chip, either in your country or in the countries nearby, send you some, and see what's going on.
pic18f phantom breakpoints pickit2
hi funnynypd, regarding your pickit 2 schematic, for aux pin there is a 4.7k ohm pull down resistor(for future). but when we need to program the eeprom(24lc), the sda line must pull up right?so is that 4.7k ohm resistor affects the aux data line during program/ reading?
who success read/program 24lc eeprom? is there any connection difference between fast programming and without fast programming?
thanks in advance...
    funnynypd
update firmware in pickit 2 linux
hi funnynypd,
thanks for your answer. if like that i suggest you to pull up the resistor instead of pull down so that no resistor pull up on the 24lc side anymore.
please remember to share your testing result. i think i will also test is using my microchip pickit 2.
thanks
    funnynypd
pic18 lvp real ice
Shipping kills the deal...
