about cadence simulator -- hspiceS
sky&sea
Junior Member level 1
cadence hspice init
when try to choose hspiceS as the simulator in the cadence IC5141,there was always an eoor"command hspice not found" and "unable to open nmos_3p3 mode"
i am a newer,who can give me some help ?Once graphics were offered will be better, thanks.
cadence met1
Need to install Hspice package from Avant! (Synopsys)
hspices
hSpic is tool of cdENXX. Need to installed and configure.
when i load the linux hspice2005.09 and config,there are warns as follows,who may geive me some help?thanks very much
lic:
lic: FLEXlm: v8.4b
lic: USER: lhg HOSTNAME: localhost.localdomain
lic: HOSTID: 001bb9709a05 PID: 8427
lic: Using FLEXlm license file:
lic: /usr/synopsys/X-2005.09-SP1/hspice/license.dat
lic: Checkout hspice; Encryption code: 8CFD037DDD14A01D864E
lic: License/Maintenance for hspice will expire on 1-jan-0/2019.12
lic: NODE LOCKED DEMO license on host 001bb9709a05
lic:
Init: read install configuration file: /usr/synopsys/X-2005.09-SP1/hspice/meta.cfg
Init: hspice initialization file: /usr/synopsys/X-2005.09-SP1/hspice/hspice.ini
**warning** .prot and .unpr not matched in file /home/lhg/pdk/chrt35/models/HSpice_Models/sm083006-1k.hspice
* reading file: /usr/synopsys/x-2005.09-sp1/hspice/hspice.ini
*.prot
*.option
+ search=/usr/synopsys/x-2005.09-sp1/hspice
**** add any user options, parameters, model includes,
**** subcircuit includes or libraries here
*.unprot
* linux fri jan 4 15:55:35 2008
* program /home/lhg/assura314/tools/assura/bin/32bit/advgen
* hspice library
.option post
.lib '/home/lhg/pdk/chrt35/models/hspice_models/sm083006-1k.hspice' typical
.endl
.lib '/home/lhg/pdk/chrt35/models/hspice_models/sm083006-1k.hspice' resistor
.endl
.lib '/home/lhg/pdk/chrt35/models/hspice_models/sm083006-1k.hspice' capacitor
.endl
.lib '/home/lhg/pdk/chrt35/models/hspice_models/sm083006-1k.hspice' bjt
.endl
.subckt inv vdd gnd in out
* caps2d version: 8
* transistor cards
mnm0 out#1 in#4 gnd#3 gnd#1 nmos_3p3 l=0.35u w=5u
+ ad=4.25p as=4.25p pd=11.7u ps=11.7u
+ fingers=1 effw=5e-06
**warning**: parameter fingers is ignored
**warning**: parameter effw is ignored
mpm0 out#2 in#3 vdd#1 vdd#2 pmos_3p3 l=0.35u w=5u
* resistor and cap/diode cards
re1 in#3 in#1 53.5714 $poly2
re2 in#4 in#2 53.5714 $poly2
rd1 in#1 in 10.4969 $met1
rd2 in in#2 10.5735 $met1
rd3 vdd#1 vdd#3 1.9049 $met1
rd4 vdd#3 vdd 0.1824 $met1
rd5 vdd#2 vdd#3 1.5000 $met1
rd6 gnd#2 gnd 1.424e-02 $met1
rd7 gnd gnd#3 1.6428 $met1
rd8 gnd#1 gnd#2 11.0000 $met1
rd9 out out#1 1.6351 $met1
rd10 out out#2 2.0084 $met1
* capacitor cards
c1 gnd#3 in#2 2.830e-17
c2 out#1 gnd#1 7.532e-17
c3 vdd#1 in#3 9.684e-17
c4 in#4 gnd#1 9.823e-17
c5 in out 2.397e-17
c6 out#2 in#3 9.802e-17
c7 out#2 vdd#2 9.855e-17
c8 in#1 gnd#1 2.563e-16
c9 vdd gnd#1 6.102e-16
c10 in#3 vdd#2 1.090e-16
c11 vdd#1 in#1 2.772e-17
c12 in#2 gnd#1 5.214e-16
c13 in#1 out#2 7.810e-17
c14 in gnd#1 2.879e-16
c15 out#1 in#4 1.008e-16
c16 in out#2 2.147e-17
c17 in#1 vdd#2 2.448e-16
c18 out gnd#1 1.704e-16
c19 gnd#3 in#4 9.919e-17
c20 gnd#3 out#1 3.150e-16
c21 in#2 out#1 8.937e-17
c22 vdd#2 gnd#1 1.024e-17
c23 out#2 vdd#1 3.148e-16
c24 vdd gnd 5.071e-18
c25 in gnd 7.026e-18
c26 out gnd 3.433e-18
c27 in#3 gnd 5.071e-18
c28 in#4 gnd 1.396e-17
c29 in#2 gnd 1.253e-18
c30 vdd#2 gnd 3.433e-18
c31 out#1 gnd 7.026e-18
.ends inv
x vdd 0 in out inv
vdd vdd 0 1.5
vin in 0 ac 40m
r out 0 1k
.ac dec 10 1 0.1g
.probe
