minimum grid in the layout?
JackyH
Newbie level 6
cadence snap to grid off
In the layout, the X snap spacing and Y snap spacing can be setted.
I had setted these spacings as 0.005 when I drawed the layout, but afterwards, I found there seems to be a minimum gird setting defined by the technology. This minimum grid is probably 0.05 um in the technology.
SO are there any problems if my spacings settings is too small, will it influence the chip fabrication?
thanks a lot!
skill and offgrid
You can't go below the manufacturing grid. If you go smaller the the Mgrid round off errors to the nearest Mgrid will occur during mask writing.
    JackyH
off grid error skill round
hii
no you cant go bryond grid setting
there are some skill coding in which you can set all the things in to new grid
ttry for that
An@layouT
    JackyH
yes there is. if your'e using a tool that has a snap to grid function. it helps. just make sure that your'e using a process that also uses 1 type of grid.
    JackyH
how can I find the snap to grid function in cadence layout window?
hi,
first never go beyond the minimum precision. this will give you OFF GRID errors. believe me this is the WORST DRC error. you have to do your layout again at most if you encounter this error. if a spacing requires 0.15 um put your accuracy to 0.1, then just go for 0.2 um spacing. well if you really want to save space, then you can go down to 0.01 accuracy but i don't think it will really give you a lot of saved space especially when your layout is just a small one.
are you using virtuoso? you can go the options menu then click the display pull down menu. you can see the x and y snap spacing.
hope this helps.
- al :)
    JackyH
The minimum grid is specified by the foundry.
During fabrication, the fabrication tip moves only on the grid. so all the off-grid points will not be formed properly. In some cases the artifacts or some other minor shapes can be waived for off-grid. devices should not be offgrid.
    JackyH
From my own experience, after my DRC execution many offgrid errors appeared on the drc report. I think they will not fabricate a layout w/ drc errors unless those are proven psuedo errors.
    JackyH
you are right .Offgrid errors must be fixed.
    JackyH
