conversion difficulties (from VHDL to Verilog..!)
salma ali bakr
Advanced Member level 3
icarus verilog vhdl conversion
I'm converting some codes from VHDL to Verilog, and I have some difficulties in:
for example in VHDL, we can write something like that:
d : in std_logic_vector; --unconstrained vector or ports
where the size of this vector is determined at instantiation by the width of the input signal connected to it...what's the similar form of this in Verilog, if any?
Also, if I'm using this vector in the architecture, I'll use signal'range since I don't know its width, what's the similar to it in Verilog, if any?
d <= (d'range => '0');
thank you :D
Hi
What tool you use?
tnx
modelsim...
are unconstrained ports (VHDL) supported by all tools...?
is there something like them in Verilog...???
In Verilog you can set some Parameters or Defines.
One to one conversion is difficult, especially when Verilog can probe signals inside modules..
AA Salma,
Try this free tool at http://www.ocean-logic.com/downloads.htm
In addition to this, any HDL compiler that compiles both languages can make conversion. Check your tool documentation.
BR,
Amr Ali.
